Author Topic: NEWSSSSS  (Read 4234 times)
Yuri
NEWSSSSS
« Reply #1 on: October 16, 2008, 01:28:00 AM »
yes, the 3000GT and the Capri use H4666 sealed beam lights. May I suggest Sylvania Silverstars? They make night driving great.
NEWSSSSS
« Reply #2 on: October 16, 2008, 11:13:00 AM »
Hey Guys! They might be worth a try, but they use H4 bulbs; not HID. Hey Yuri, do you have the silverstars in one of your cars?  Gus
D22A
NEWSSSSS
« Reply #3 on: October 17, 2008, 01:44:00 PM »
I looked capris  springs and shocks then i looked 93 civic  and size of the springs ara olmoust  same  I thinking to buy  groung control colivers  and they cost $45 with shiping much chiper then  capris
1996 MT 3000GT LS
1993 CAPRI n/a
NEWSSSSS
« Reply #4 on: October 17, 2008, 02:18:00 PM »
Hey D!  You're playing with fire when things are almost. Especially in suspension pieces, if it's not right don't do it.  Gus
D22A
NEWSSSSS
« Reply #5 on: October 17, 2008, 02:29:00 PM »
ok, my cars oil pressure was very low and i chainged my oil filter only oil filter and pressure is great  when I push the gas   oil pressure gos more then 75% up,  if ou have problems   with oil pressure you shude change oil and oil filter and thei is uther filter 1 inch biger from mazda 626 engines
 The part number for these are Carquest # 85356 or Fram # PH7317. This filter has the exact same specifications as ours except that it is 1" longer.This means more cleaning power for our hi-revving engines. My engine still held only 4 qts of oil after installing the new filter. Hope this helpful
1996 MT 3000GT LS
1993 CAPRI n/a
