Author Topic: bypass valve  (Read 8661 times)
annie151
bypass valve
« on: May 06, 2009, 02:53:00 AM »
I am working on my own car and I am sort of mechanically inclined.  I have an aftermarket issue though...  Does any have a picture of a bypass valve?   I had been told to order bov valve in place of one but I am having a difficult time on how to install it?  Is there an aftermarket kit I need to order?
bypass valve
« Reply #1 on: May 06, 2009, 06:51:00 AM »
Hey Annie!  If you ordered the one Rocketman featured then it's an easy adaption, if not then you've got hell to pay. To answer any further would require a picture of your unit.  Gus
annie151
bypass valve
« Reply #2 on: May 06, 2009, 07:04:00 AM »
I did order the one rocktman said to.
BYPASS VALVE AUDI A4 A6 TT S4 VW PORSCHE TURBO
 http://cgi.ebay.com/ebaymotors/BYPASS-VALVE-AUDI-A4-A6-TT-S4-VW-PORSCHE-TURBO-BOSCH_W0QQitemZ260403661862QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3ca1448c26&_ trksid=p4506.c0.m245&_trkparms=72%3A1205%7C65%3A12%7C39%3A1%7C240%3A1318
what does the old bypass valve look like...maybe I am replacing the wrong part?
bypass valve
« Reply #3 on: May 06, 2009, 11:37:00 AM »
Hey Annie! This in suppliment to the existing unit. I thought there was a photo showing it installed in one of the posts. I don't know how to post photos so hopefully someone can butt in with a photo.  Gus
bypass valve
« Reply #4 on: May 06, 2009, 03:16:00 PM »
Guss, this is to replace the old unit - you do not keep it.
Annie,
Find the crossover pipe on top of the valvecover - its the silver metal pipe running over the top of the engine. On the right side of it near the throttlebody - there is a small piece of rubber hose that connects the crossover pipe to a metal hardline. The hardline will run off the side of the engine past the distributor and make its way down under the turbo intake pipe. The stock bypass valve is down there, you'll find it by tracing the line. Its round and it'll have two 3/4" hoses and a vacuum line on it.
You may be able to directly replace the stock valve, or you might need to get some flexible hose of the proper diameter and get creative. As long as you have the in/out properly connected everything should be fine. At one point I replaced that metal hardline with a length of rubber hose, you might need to do that.
Maybe Grant can post up some pictures of his install?
-Matt
bypass valve
« Reply #5 on: May 06, 2009, 03:31:00 PM »
Hey Rocket!  I'm sinking deeper in my halucinations. Can't spell, my feet swollen beyond belief; no sleep. Life's a living hell right now.  Gus
yen
bypass valve
« Reply #6 on: May 06, 2009, 07:33:00 PM »
Geesus Gus, what happened to you?
1990 Ford Capri
1.6L SOHC
annie151
bypass valve
« Reply #7 on: May 07, 2009, 05:51:00 AM »
cool...that's what I was thinking where it goes...but what's the innie and what's the outtie on the bov?
annie151
bypass valve
« Reply #8 on: May 07, 2009, 05:53:00 AM »
Hey Gus....don't go into the light.....
But all seriousness...I hope you are ok?
annie151
bypass valve
« Reply #9 on: May 07, 2009, 06:15:00 AM »
Guess what capri group....my car is up and running again...  I figured out how to connect the bov ....thanks once again to this marvelous website...I hope I do not need to come back again for technical issues...only just for fun.
bypass valve
« Reply #10 on: May 07, 2009, 09:38:00 AM »
Hang in there Gus!
Annie, glad you got everything hooked up right. No more funny noises right?
bypass valve
« Reply #11 on: May 07, 2009, 10:18:00 AM »
Hey!  Just got back from lunch at chinese smorgy.  Guess what?  I'm starting to make mooing noises also. Gonna have to look into a new BOV.  Gus
annie151
bypass valve
« Reply #12 on: May 08, 2009, 01:52:00 AM »
No funny noises.....that did the job.
Thanks Rocketman...
annie151
bypass valve
« Reply #13 on: June 12, 2009, 10:29:00 AM »
ok having problems again....the bov sounds like it's mooing again..I took a picture of how I set it up...can you tell me if this is right?  Ok how do I download a picture?
bypass valve
« Reply #14 on: June 12, 2009, 01:30:00 PM »
post to photobucket then link it here
