Author Topic: turbo on 91 capri na, 5 speed  (Read 10931 times)
dajeman
« Reply #15 on: December 24, 2011, 05:07:00 AM »
Can u tune to compensate for more airflow? Add gas flow w afr
« Reply #16 on: December 24, 2011, 05:10:00 AM »
I've done the AWD conversion. It requires a lot of cutting & welding & some custom parts. I have pictures on my website, check it out. It took me 2 years and a couple thousand bucks to collect the necessary parts.
The 2.0 is the FS engine, it's even longer than the BP so it'd be a tough fit. The ford Zetec engine should fit though, but the transmission/axle combos required to make either fit start to get really tricky
« Reply #17 on: December 24, 2011, 05:12:00 AM »
Quote
I've done this for the XR2. Check out my FAQ: www.werbatfik.com/ecu.htm
I don't have an N/A and it uses different ECU programming, so I've not tuned one. For an N/A there isn't a whole lot to be gained from ECU mods
dajeman
« Reply #18 on: December 24, 2011, 05:16:00 AM »
Where can I get a good adj Fuel press reg for this car?
