Author Topic: Bypass valve  (Read 6736 times)
annie151
Bypass valve
« on: April 28, 2009, 08:32:00 AM »
Hi capri group....I finally had my turbo rebuilt and now my car does not smoke like it use to...but it is making a grinding noise?  I was told to change the bypass valve.  Is that right...if so...I cannot find one...HELP!
Once again I turn to the greatest capri help group ever.
Bypass valve
« Reply #1 on: April 28, 2009, 09:28:00 AM »
Is it grinding? Or is it closer to a mooing or flapping noise? If it is then yes its your bypass valve.
bhazard
Bypass valve
« Reply #2 on: April 28, 2009, 11:32:00 AM »
Grinding doesnt sound like the BPV, mine sounds like a high pitched moo. My gf thought there was a ghost under the hood. I wanna replace mine with an SSQV.
annie151
Bypass valve
« Reply #3 on: April 28, 2009, 11:51:00 AM »
It's kind of hard to describe...i would say it's a high pitch moo.  Also turbo is not as powerful as it was before it was rebuilt...do you think they screwed it up?...I don't see how.
annie151
Bypass valve
« Reply #4 on: April 28, 2009, 11:52:00 AM »
oops...forgot to mention my turbo was just rebuilt.
Bypass valve
« Reply #5 on: April 28, 2009, 12:46:00 PM »
Hey Annie!  You didn't forget to mention rebuild of turbo. But maybe your description of noise needs better splainin', eh Lucy. Is it mooing or a grinding. Did you check the turbo for free spin before resetting it? Cause a grinding would mean the turbo fins are hitting the housing, not good! I myself have often wondered hat all the mooing is about, so I've learned from your question. At least now I can stop looking over my shoulder wondering if I'm going to get trampled by the ensuing stampede under my hood. Also how much boost are you showing in regards to less power and check your dist timing, 12 degrees.  Good Luck Gus.
Bypass valve
« Reply #6 on: April 28, 2009, 12:47:00 PM »
double check all the vacuum lines. the noise you hear is more then likely the air going back into the intake pipe from the BOV. mine makes the same noise and i can't wait to put on a aftermarket one myself
annie151
Bypass valve
« Reply #7 on: April 29, 2009, 02:54:00 AM »
bypass valve....bov.....eish...so many things to check...so little time to drive it.  I am an idiot with turbos and I am trying to understand the knowledge of it by reading the other posts..but it throws me in a loop.  What's the difference between the two and how do I check them?
Bypass valve
« Reply #8 on: April 29, 2009, 07:11:00 AM »
Hey Annie! A different name for a part that performs the same service. Gus
annie151
Bypass valve
« Reply #9 on: April 29, 2009, 09:14:00 AM »
where's a good place to get one and what price range am I looking at?
Bypass valve
« Reply #10 on: April 29, 2009, 11:30:00 AM »
Click here for an Ebay auction that is selling the item that will help you out.
something like that would do nicely, I think Grant is running something very similar to this
 [ April 29, 2009, 06:05 PM: Message edited by: STE_6000 ]
annie151
Bypass valve
« Reply #11 on: May 01, 2009, 03:40:00 AM »
Hey Rocketman,
I bought the bov per your instructions.  They shipped it out pretty quick...next day.  I hope to have it by middle of next week.  I so hope this does the trick....thanks again...
to be continued......
Yuri
Bypass valve
« Reply #12 on: May 01, 2009, 04:05:00 AM »
yup.. mine's just red
annie151
Bypass valve
« Reply #13 on: May 04, 2009, 06:15:00 AM »
I just rec'd the bov for my car....
Do I need some kind of adapter kit?
How do I install this?
Clubby
Bypass valve
« Reply #14 on: May 15, 2009, 12:26:00 AM »
Hi All,Thanks for the great info,never new what that mooing noise was LOL i,ve put a BOV in and the cow is gone,not only that the car has more power now,Thanks Guys  ;)
