Author Topic: Starting problems  (Read 2903 times)
1992xr2
Starting problems
« on: April 01, 2008, 04:43:00 AM »
Hey,
I developed a very strange problem this morning, when I start the car everything is normal until the key goes to the start position.  When the key is in the start position, power completely cuts out to everything, no clock, gauges, lights, nothing.  Battery voltage is 12.75.
Thanks
\\\'90 Civic Si
Boost in the near future.
GrooveNerd
Starting problems
« Reply #1 on: April 03, 2008, 08:50:00 PM »
Depending on how the switch is connected inside, it could be a bad ignition switch.  It may be a bad connection to the switch or somewhere in the starting circuit also.  Without looking at wiring diagrams and stuff, that's what I'd check first.
1993 Capri XR2, Emerald Green (123,xxx mi)
1998 Contour SVT, Black  (159,xxx mi)
1987 Escort Wagon, Met. Blue (271,xxx mi)
1982 Escort Wagon, Silver (372,xxx mi)
1992xr2
Starting problems
« Reply #2 on: April 04, 2008, 05:00:00 AM »
I fixed this last night, in spite of looking perfectly ok and testing perfectly ok one of the wires from the battery had an intermittent fault.
\\\'90 Civic Si
