Author Topic: a/c compressor  (Read 3394 times)
a/c compressor
« on: July 22, 2011, 04:21:00 PM »
Anyone know if the 1994 capri ac compressor (r134a) is a direct replacement for any of the earlier years, or do things not line up (bolts, pulley, etc)?
a/c compressor
« Reply #1 on: July 22, 2011, 05:59:00 PM »
I "think" it's the same. I've never tried to install one, but I've removed quite a few and they appear to be the same to me
a/c compressor
« Reply #2 on: July 22, 2011, 06:01:00 PM »
IIRC the 94 compressor is completely different, it is designed for R134a. I don't know if they can interchange, my guess would be probably not though
a/c compressor
« Reply #3 on: July 22, 2011, 06:33:00 PM »
you need all the lines to go with it or at least get some made.
a/c compressor
« Reply #4 on: July 22, 2011, 07:35:00 PM »
I think what he is asking, is can you put the 94 A/C system in a 91-93 car, and have everything line up right, with no mods.
My answer is still "I believe so"
a/c compressor
« Reply #5 on: July 22, 2011, 07:50:00 PM »
He's asking if the compressor in a 91-93 can be replaced with one from a 94. I don't think it can directly
a/c compressor
« Reply #6 on: July 22, 2011, 09:05:00 PM »
You'd have to swap out all the lines from a 94, as well, correct?
a/c compressor
« Reply #7 on: July 23, 2011, 03:57:00 AM »
yes. need a new compressor since I can't find a cheap clutch. system already converted to r134a, wondering if I should just get a 94 compressor. many sites list them as 91-94 and wondering if that was correct.
a/c compressor
« Reply #8 on: July 23, 2011, 05:08:00 AM »
I have a 94 compressor here if you wanted to give it a shot......
a/c compressor
« Reply #9 on: July 23, 2011, 05:13:00 AM »
He will need the compressor & lines in the engine bay if using the 94 parts
a/c compressor
« Reply #10 on: July 23, 2011, 06:15:00 AM »
What's different about the lines? bends, types of flair, what?
a/c compressor
« Reply #11 on: July 23, 2011, 09:16:00 AM »
The connection at the compressor & the servicing ports are different.
if you got the 91-93 compressor then you just need to convert the fittings for the R134
