Author Topic: 1991 Capri  (Read 3035 times)
jdyb170
1991 Capri
« on: December 18, 2009, 08:29:00 AM »
I have a 1991 mercury capri and located on the engine block is a hole, (next to the oil cooling unit).  what goes in that hole? a plug? a hose?
1991 Capri
« Reply #1 on: December 18, 2009, 10:39:00 AM »
photos will help here
1991 Capri
« Reply #2 on: December 18, 2009, 02:07:00 PM »
One of these?
One's a knock sensor and one's the oil pressure 'sensor'
jdyb170
1991 Capri
« Reply #3 on: December 19, 2009, 01:14:00 PM »
hi thank you for getting back to me.  I appreciate that.  My brother says that both sensors are there, in place,  the hole is about 4 inches lower than those.
1991 Capri
« Reply #4 on: December 19, 2009, 11:29:00 PM »
does the hole your refering to have a 1/2-3/4 inch bung, with a thick rubber cap.... a bung the same size as the L-shaped oil return lookin rig on the oil pan???
if thats what you guys are talking about...
those are bungs left over from the rally car days when mazda ran a sort of PCV system like a jetta uses... with a pump to evacuate crankcase gasses.. i think it was experimental, for WRC...
ive got a block in my garage ill try to get a photo of the back side of it.. see if we can't solve this mystery...
jdyb170
1991 Capri
« Reply #5 on: December 20, 2009, 08:16:00 AM »
the bung is there with the rubber cap, about 4inches above the bung is where the hole is located .
bryanknight
1991 Capri
« Reply #6 on: December 21, 2009, 03:32:00 PM »
the only hole i see on my block above the the bung is a freze plug on the right side of the oil cooler ??? and you can see it in rockets pick?? is that what your talking about ?
