Author Topic: strut mounts  (Read 3285 times)
sterling94capri
strut mounts
« on: August 21, 2008, 05:04:00 AM »
I JUST ORDERED SOME STRUT MOUNTS THAT WERE ON CLOSE OUT FROM TIRE RACK, THEY ARE FOR A 1989 MAZDA 323 GT, KYB 1 FRONT, 2 REAR. THEY ONLY HAD 1 FRONT! I HAVE A 94 XR2,THEY SHOULD FIT ...RIGHT???
ROCKY
STE_6000
    • http://teamcapri.com
strut mounts
« Reply #1 on: August 22, 2008, 01:02:00 AM »
you should be good, the one that wont work is the gtx mounts, but i think for the gtx it is only the rear.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
sterling94capri
strut mounts
« Reply #2 on: August 22, 2008, 03:29:00 AM »
thank you anthony,now all i have to do is find some coil overs on close out ha!
ROCKY
strut mounts
« Reply #3 on: August 22, 2008, 06:15:00 AM »
Hey Rocky! Are you talking about the upper strut bearing? And your car is already lowered, correct?  Gus
sterling94capri
strut mounts
« Reply #4 on: August 23, 2008, 06:07:00 AM »
YES GUS,IT IS THE UPPERS,I GOT ONE FRONT AND TWO REARS FOR 51.70, THATS WITH SHIPPING! MY CAR IS NOT LOWERED,IT IS A 94 XR2,SO IT IS LOWER THAN 91-93S BUT I WANT TO PUT COIL OVERS ON SOME DAY AND I ASSUME IT WILL NEED NEW MOUNTS. THANKS
                                      ROCKY
strut mounts
« Reply #5 on: August 23, 2008, 09:44:00 AM »
Hey Rocky! The upper strut bearing seldom goes out is why I inquired. When you use the term coil over, are you referring to factory strut with spring? The ride height on your car now is approximately the same as if you bought H&R springs. I have two '94XR2s myself and I have two '91XR2s that I've installed H&Rs on. The front ends are virtually the same height on all four cars.  Gus.
sterling94capri
strut mounts
« Reply #6 on: August 25, 2008, 07:05:00 AM »
I WAS THINKING OF GROUND CONTROL COIL OVER, THEY ARE ADJUSTABLE FROM 0 TO 2 1/2 INCH DROP, FOR 399 PLUS SHIPPING. WHAT DO YOU THINK?
STE_6000
strut mounts
« Reply #7 on: August 25, 2008, 05:59:00 PM »
im running ground control coil overs now.
Anthony
-Tinted Windows 20%
-Corsa Exhaust
