Author Topic: Oil pressure sender  (Read 2811 times)
1992xr2
Oil pressure sender
« on: March 26, 2008, 02:54:00 PM »
Hey,
Does anyone have the FSM or information about testing the oil pressure sender?  I think either my headgasket, turbo or oil pressure sender is causing massively low (pegging the needle low) oil pressure readings.  If no one has this I'll just buy a cheap electronic gauge but I'd sort of like to keep the factory one.
Thanks
\\\'90 Civic Si
Boost in the near future.
