Author Topic: 91 xr2  (Read 4022 times)
bryanknight
91 xr2
« on: May 28, 2008, 04:03:00 PM »
does anyone know how to check the check engine light from the ecm   i know you put a wire from one plug to another and look on the dash for the light flashes  but which ones??? thanks
bryanknight
91 xr2
« Reply #1 on: June 04, 2008, 10:33:00 AM »
???? anyone ????
STE_6000
    • http://teamcapri.com
91 xr2
« Reply #2 on: June 04, 2008, 12:45:00 PM »
not me, im suprised rocket hasnt jumped on this yet.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
bryanknight
91 xr2
« Reply #3 on: June 04, 2008, 03:17:00 PM »
someone has to know   because how are you checking the codes for the check engine light ??? i am working on fixing the crank pulls right not now  but i would like to know how to check the codes when i get it running again
91 xr2
« Reply #4 on: June 04, 2008, 03:47:00 PM »
You have to jumper the green connector IIRC...but there are 3 wires going into it. I am not sure which of the lines it is.
If I can dig up my manual I'll try to find out for you.
Spanky
91 xr2
« Reply #5 on: July 05, 2008, 02:31:00 AM »
Ground the STI connector RH rear corner of engine compartment. Mine is green. The wire will be yellow.
Yuri
91 xr2
« Reply #6 on: July 05, 2008, 02:39:00 AM »
i used to go to advance auto parts and have them plug their scanner into the car... then someone broke it. Now they only have odb2 scanners.
Yuri
91 xr2
« Reply #7 on: July 05, 2008, 02:44:00 AM »
this is what i believe they had http://www.amazon.com/gp/product/B000KID2ZC
it should work, as i believe our cars are fitted with the EEC-IV system, which this thing reads
91 xr2
« Reply #8 on: July 05, 2008, 03:17:00 PM »
We have MECS (Mazda Engine Control System). The OBD1 scanner might be able tell you basic info but from what I understand its not fully OBD1 compatable.
Spanky, where in PA are you?
spiro
    • http://N/a
91 xr2
« Reply #9 on: July 06, 2008, 11:34:00 AM »
It says "Post" 1996 for that scanner... ?
spiro - 1989 SA Ford Capri
Spanky
91 xr2
« Reply #10 on: July 06, 2008, 12:13:00 PM »
Rocketman, I'm Corry PA. Northwest corner below Erie, above Pittsburgh.
