Author Topic: mitsubishi turbo swap info (hp and CFM)  (Read 4998 times)
« on: May 25, 2009, 04:06:00 PM »
more turbo info for anyone thinking about mitsubishi turbo swaps....
theese are a bit bigger than what ihi turbo guys are used to....
Mitsubishi Turbo Information (UPDATED)
(1/17) > >>
Wrath:
Here's some info i got off the DSM VFAQ, thought you guys might find it useful..
Flow Rates @ 15psi:
TDO4-9B-6CM2  265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2  465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen)     275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
http://www.vfaq.com/mods/Turbo-compare.html
stainless:
look like mi need fi throw on a mitsu turbo [whistle]
TD04 sounds cool still
BTW u live in portmore king, cause mi see a car at the shell Naggos Head last nite weh look like urs still
Wrath:
yeah i live in portmore....was probably my car you saw last nite
Rx:
Just a little info from a mistu brochure to supplement wrath's excellent post:
Evolution 1
Turbo = TDO5H–16G-7
Nozzle Area (cm2) = 7
Exhaust turbine = Inconel (steel alloy)
Compressor = Aluminium, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Turbine = Inconel (steel alloy)
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminium, 68mm wide
Evolution 4
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
             TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
Turbine = Inconel (steel alloy), Titanium alloy (RS)
Evolution 6
             TD05HRA-16G6-10.5T (RS/rs2)
Turbine = GSR - Inconel (steel alloy), Titanium alloy (RS/RS2)
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
             TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = GSR - Inconel (steel alloy), RS/Rs2=Titanium alloy
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
Compressor = Aluminium, 65mm wide
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM E8)
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
 RS/Rs2=Titanium alloy.
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
sae2:
Zeen,so can a Evo 7 turbo bolt directly on to a 93gst,no fabrication,and without causing any internal damage [question]
Navigation
  • Message Index
  • Next page
« Reply #1 on: May 25, 2009, 04:23:00 PM »
did you make a flange to fit the stop manifold or cut and weld a flange on?
JackRobot
« Reply #2 on: May 25, 2009, 04:43:00 PM »
I'm planning on going 16g with custom manifold, but that's quite a while away yet.
« Reply #3 on: May 25, 2009, 05:46:00 PM »
made the flange, and centered the stock mani on top of it, and welded arround it with nickel rod.
i ground out the 4 corners to give clearance to the new flanges bolts before welding...
 looking at the ihi flange on the mani it went from a square to a + symbol  to clear the bolt holes on the mitsu flange
 ill take some better pics sometime to show better how it was flanged... i did not cut the flange off the mani... just added to it
« Reply #4 on: May 26, 2009, 03:21:00 PM »
looks like you never added it to me..as far as i can see. so whats the clearance like when installed?
« Reply #5 on: May 26, 2009, 03:49:00 PM »
ive got a 14in slimline pusher on the front of my radiator, and with that thares plenty of room
the pipes will be wacky where the mitsu is a wierd turbo.. but it will fit ..
oh, the stock wastegate cannot be used with my manifold.. it hits the ear on the block where the tranny bolts up..im gonna try an ihi wg actuator and ill let ya know more...Joe
« Reply #6 on: May 26, 2009, 03:51:00 PM »
aah, ill bring it to the macg so everyone can see how it was made...
