Author Topic: Clutch/Flywheel hitting on something  (Read 2731 times)
bhazard
« on: March 30, 2010, 01:01:00 PM »
New clutch and resurfaced flywheel. I've got everything back together and hit the starter. It turns over but is clunking. I turn it over with a wrench and every 90 degrees or so something hits in the upper bell housing. If I push really hard I can get past it, I know, not a good thing to do.
Any ideas before I rip it all back out of the car or send the whole thing to "M&K Metals"?
« Reply #1 on: March 30, 2010, 07:09:00 PM »
Is one of your pressure plate bolts sticking out? I'm not really sure what else would cause it
bhazard
« Reply #2 on: March 30, 2010, 07:30:00 PM »
Everything was torqued...looks like ill be pulling it out. Something in there will be shiny. It'll probably end up being something incredibly dumb...
bhazard
« Reply #3 on: April 01, 2010, 02:32:00 AM »
« Reply #4 on: April 01, 2010, 06:11:00 AM »
wow...never seen that before. Looks like the pressure plate is out of tolerance. Simple fix?
Phillip
« Reply #5 on: April 01, 2010, 09:23:00 AM »
Is this the only part making contact? What kind of pressure plate?
