A good battery should never read 11 volts, unless there is a significant current draw off the battery.
Just wondering what alternator you are using, the bosch or mitsubishi? Bosch has a visible cooling fan. I had a bosch go bad once on a 91, measured 14.5 engine on, good battery, yet battery drained within a few days of non-use. Turned out the voltage regulator on the bosch had gone bad, and was allowing current flow, engine off, draining the battery. I tried 2 times replacing the voltage regulator, kept getting defective China ones, so gave up and converted bosch to mitsubishi plug and installed a mitsu I had laying around. No more issues.
If you actually are reading only 12 volts at times with the engine on, and this has happened with both alternators, I'd also consider the connector at the alternator to be flakey.
Something else that doesn't exactly fit with your description of events is a light bulb in the trunk or glove box staying on all the time due to a faulty trunk or glove box switch...
