Author Topic: Defroster relay  (Read 2089 times)
Defroster relay
« on: November 29, 2015, 01:39:28 PM »
Where is the defroster relay in the trunk? I see a relay attached to the red fuel pump reset button casing. Is that it, or am I missing where it goes?
Re: Defroster relay
« Reply #1 on: November 29, 2015, 08:24:00 PM »
Yep that's it. If you follow the wire harness back off the inertia switch you'll come to a Y. That other part if the Y goes to the defrosted relay. If I ain't mistaken there are some black/yellow and a black wires going to it. There are two fuses to the circuit. If you need to know them I can look it up.
Re: Defroster relay
« Reply #2 on: December 02, 2015, 07:28:16 AM »
Interesting. yes, that must have been it b/c I have defrogger!
I don't think the car had a hardtop originally, or ever.... Wonder if that relay came from the factory....?
