Is that small short pipe just dumping to atmosphere?? Looks like a tite fit. Did you have to machine the actuall exhuast manifold? I now have 3 manifolds, 1 that is perfect, one with a small crack, and one that is junk. I'm going to pull the AC also, to make more room, move the battery to the back. The pictures that Matt ran of his intake is also what I will try to do, shorten it up and make it as straight as possible. Bend some aluminum, like you did Joe, to keep it dry and suck some cooler air. Rewire the fuel pump tmrro. Got a monday off, but have to work on sat.
