Harness is near the jumper, on the front passenger side under the hood. Jumper is a standard ford plug, but like he said I firmly recommend just grounding the jumper and pulling the codes. It's a single wire connector, just wire it to a ground nearby. Then put the key in and count the Check Engine light flashes. Either get a shop manual, or repost your codes and I'll flip through mine.
