Pages: 1 ... 3 4 [5]
Author Topic: Replacing an engine  (Read 14688 times)
Replacing an engine
« Reply #60 on: August 24, 2011, 02:02:00 PM »
Okay, I managed to get a thermostat in the car, but now the car runs about 195 average, and peaks around 210-225 as per the gauge.
Is this something to be worried about, or is it only a problem when the gauge pegs?
Replacing an engine
« Reply #61 on: August 24, 2011, 06:14:00 PM »
It should sit here, and maybe a tick above before the fan comes on if you are sitting.
 If it is running higher than that you have something wrong with the cooling system. Did you put in a 195° thermostat?
Replacing an engine
« Reply #62 on: August 25, 2011, 02:29:00 AM »
Mine sits there at about 50mph, but at idle in traffic it can go up to 225, the 2nd last point.  I replaced my thermostat with an OE mazda 2 stage thermostat, 198/195F.
It seems to hold pretty well when it's cold out, so I'm going to try to flush it out again and see if I can't clear out all the orange junk that got left when some idiot put sealant in it.
