Tech, Repairs, Upgrades => Capri XR-2 89-94 => Topic started by: Kiwimagic on July 16, 2020, 12:01:11 AM
As I stripped a donor VJ 14 Turbo I have had a small amount of oil leaking out of the waste gate actuator. Not a lot but when I left it on my work bench over night in the morning there was a small pool (1 cm in dia) of oil under the air connection.
Where would have this oil come from ??
The only place I can think of is the actual compressor /Turbine housing itself. It was a 1992 Turbo so the bearing seals could have been leaking and allowing a small amount of oil into the compressor side of the unit which then gets pumped into the inlet and then into the waste gate actuator. Or is the system designed to do this.
I have noticed as I strip the Turbo from my car and run my finger around the inside of the piping there is small trace/film of oil there as well.
Should I be concerned about this ?? Or is it normal.
The valvecover breather vents into the turbo intake tube, so there is always potential for oil vapor to condense in the intake path.
A puddle of oil like that is usually indicative of a blown turbo or at least one on it's way out.
Check the donor unit for shaft play. If you grab the nut on the compressor wheel, the assembly should move side to side ever so slightly and almost none in & out.
If it is moving quite a bit it's shot and very likely the source of the oil.
Hi
The Turbine unit is new. So the oil residue could be from the old Turbine. The oil and water inlets and outlets are in different spots on the VJ11. Do you have a picture of which is which as Im not quite sure which is oil and which is water. Would not like to get them mixed. Better to be safe than sorry.
cheers
Kiwimagic
Ron.
