Author Topic: Mercury Capri clutch slave cylinder  (Read 12935 times)
quelfboy99
    • 1991 Mercury Capri base
« on: November 29, 2023, 05:03:55 PM »
hi I am a first-time mechanic and the clutch slave cylinder went bad on my Capri. As it's located in a hard-to-reach location I was wondering if you guys had any tips on getting to it. Thanks
Re: Mercury Capri clutch slave cylinder
« Reply #1 on: December 01, 2023, 07:30:48 AM »
Undo the two nuts for the front transmission mount from the underside of the crossmember, then use a jack with a block of wood on the engine oil pan to lift it up by an inch or so.
When you do this, you will roll the engine/tranny backwards giving you way more clearance for removing/installing the slave cylinder. Which can now be done easily from above by reaching down to it.
quelfboy99
« Reply #2 on: December 01, 2023, 06:32:21 PM »
thanks!
McClain
« Reply #3 on: March 29, 2024, 06:50:26 PM »
Just did my clutch and had to do a new slave cylinder. Best to drop the cross bar at the bottom for best access because I tried to do it with it in and it was very hard. Also if make sure you correctly bleed the slave cylinder because it caused me a lot of trouble to get it right, best bet is to compress it with a c clamp and then attach the hose with fluid in it or it will fill with air at the end of the slave cylinder and won’t bleed out but also won’t give you enough pressure to move the clutch. That’s my two cents on it though!
