Author Topic: Airbag light blinking?  (Read 9090 times)
Christian
« on: August 04, 2010, 06:34:00 PM »
I've heard that the airbag light blinking is some sort of trouble code, is that right? If so does anyone know what it means when it blinks 6 times and stops and does it again? and also when it blinks 10 times and then stops and repeats.
gadawgs34
« Reply #1 on: August 05, 2010, 03:53:00 AM »
my 91 is doing the same thing!!!! i was thinking of taking the whole airbag system out what do yall think about that to?  :confused:
Mike Robinson
David Young
    • 1993 XR2
« Reply #2 on: August 05, 2010, 08:21:00 AM »
I also have a 91 with a blinking airbag light.  I believe that I looked it up once in a shop manual.  It is in there, but I don't remember what all the codes are?  I think 8 0r 9 blinks is a bad ground...but I am not sure.  I did see it in there.  You may want to give that a read.
David A. Young
gadawgs34
« Reply #3 on: August 05, 2010, 08:47:00 AM »
mine is blinking 4 times   :confused:
Mike Robinson
gadawgs34
« Reply #4 on: August 05, 2010, 09:10:00 AM »
mine is blinking 4 times here are the codes
No Lamp Diagnostic Monitor Unable toLight Air Bag Lamp
Continuous Lamp Diagnostic Monitor Unable to Flash Diagnostic Trouble Code
3 LOW Battery or Backup Power Voltage
5 Air Bag Deployment Circuit Shorted lo Ground
10 Air Baa Deoiwment Circuit intermittent Short to Ground
4 Safing Sensor Diagnostic Circuit Open or Low Resistance in Crash Sensor
what do i do? can i just cut those senors or remove the fuse where ever that is?  :confused:
Mike Robinson
gadawgs34
« Reply #5 on: August 05, 2010, 09:14:00 AM »
Christian looks like you have a ground problem....pm me you email and ill send you the part of the manual you need it is a pdf   :cool:
Mike Robinson
gadawgs34
« Reply #6 on: August 05, 2010, 09:22:00 AM »
Mike Robinson
« Reply #7 on: August 05, 2010, 03:54:00 PM »
Check your rear sensor first, that's the one under the handbrake.  Then check the other sensors near the radiator.  One is under the washer fluid tank, the other is on the driver's side headlight.  I tried to fill my washer fluid one day, leaked out poured on the sensor.  Code 5-10 since then.
Christian
« Reply #8 on: August 05, 2010, 05:10:00 PM »
Thanks for the manual Mike, It helped a ton! I really dislike dealing with electrics and diagnostic codes :/ but I suppose Ill have to fix it that airbag light is almost as bad as a CEL that stays on haha Thanks guys
gadawgs34
« Reply #9 on: August 06, 2010, 05:52:00 AM »
you bet, i get alot of help from the brochachos here so when i get a chance to help out im always glad to   :cool:
Mike Robinson
aw2oban
    • 66 Stang, 92 xr2 (x2),01 F250 7.3, 03 CVPI CNG
Re: Airbag light blinking?
« Reply #10 on: October 09, 2014, 12:23:39 PM »
So if I have the same ten blink code for a ground all I do is take it apart, clean it, ad put it back or is there a sensor to replace?
9193CapriXR2
« Reply #11 on: October 11, 2023, 11:45:31 AM »
Mine blinks continuously with no discernable pause.  I counted 75 rapid fire blinks a pause then 100 rapid fire blinks.  That was right after startup.  Then while driving it started rapid fire blinking continously for well over 200 blinks....
« Reply #12 on: October 13, 2023, 09:00:56 AM »
The airbag module is a little blue box mounted on the firewall above the steering column. When you unplug it the light will stay on, just remove the light. Even if it were to be off, I don't trust those 30 year old components.
