Thanks, good to know it has been helpful.
Finally got the last seat bolt in, found it was easier to bolt the back bolts in first and used a 8mm drill bit to widen the bracket holes a bit on the bottom to fit the seat bolts better.
I have added a thread in the photo section
here so you guys can see the latest photo's in one place of my Capri 94 SE XR2 turbo...
B6T engine installFinally booked in, with a turbo mechanic who I've sourced the B6T engine with, an install date... NOV 18 - 20 weekend, bought a gates blue racing timing belt, new pulleys, new water pump aaaand a bottom radiator hose along with fluids to complete the install...
