Author Topic: 1994 power brake booster  (Read 3603 times)
« on: October 05, 2023, 12:35:37 PM »
Looking for a new / used unit... it is out of stock everywhere ... 1994 is apparently different from 19 to 93, which are available...help?
9193CapriXR2
Re: 1994 power brake booster
« Reply #2 on: October 05, 2023, 04:45:56 PM »
appears different than the one Oreillys shows.  Never seen a 94 as I have a 91 and a 93 so dont know for sure.  but that ebay link is same part number that Rockauto shows....so I dunno.  Oreillys is different but as you state out of stock
https://www.oreillyauto.com/detail/c/brakebest-brakes/brakes/brake-hydraulics/power-brake-booster/69bab478e25a/brakebest-brake-booster-remanufactured/obh3/5474118/v/a/5702/automotive-car-1994-mercury-capri?
« Reply #3 on: October 05, 2023, 06:30:19 PM »
The brake booster from that ebay link is a not the right part, that part number is 54-74418 and is completely different.
The part number for the 94 is 54-74118, while the part number for the 91-93 is 54-74113.
The 91-93 and the 94 boosters have the same single 9.238 inch diaphragm, use the same Master cylinder,  and mount to the firewall the same. The only differences that I'm aware of is that the vacuum input connection moved from the top left to the top right side and the snout that goes through the firewall has a different style rubber boot.
9193CapriXR2
« Reply #4 on: October 07, 2023, 12:53:37 PM »
Ahh sorry, my bad, keyed the number in wrong.  Next time Ill wear my glasses.
