Author Topic: 91 capri xr2 exhaust upgrade  (Read 6293 times)
turboxr291
    • 91 XR2 ,
« on: May 23, 2014, 10:08:17 PM »
I just put a 2 1/4 id exhaust system on my capri i need a header BAD!!! also whats a good intercooler system to use on this motor along with blow off an wastegate is it internal or external wastegate?
Re: 91 capri xr2 exhaust upgrade
« Reply #1 on: May 23, 2014, 10:57:02 PM »
You're throwing a lot of terms around here.
We have an internal wastegate. Port it if you ever have the turbo off.
A naturally aspirated car uses a header, and can help improve power. We have a turbo, there's no need to upgrade it unless you're going to a larger turbo & want a custom piece. Even then, there's very few benefits to be had unless you're pushing 250+hp. Very few aftermarket options for turbo manifolds on our engines.
Search around here regarding intercoolers. You'll have to piece together your own kit, there's a few threads here that detail the necessary components.
Same with the BOV - quick recommendation would be a Greddy type RS clone or an HKS SSQV clone.
9193CapriXR2
« Reply #2 on: October 29, 2023, 03:35:31 PM »
What is used to upgrade the pipe size from turbo to 2.25.  I have cat, muffler, and pipe in 2.25 but curious what was used to go from the turbo to connect to the 2.25 exhaust pipe.  Is there a flange or adapter of some sort.  I havent gotten under the car yet, but want to mock up the exhaust to have it welded up before attaching to turbo.
NEDREBEL
« Reply #3 on: October 30, 2023, 11:45:38 AM »
What are you guys using for exhaust? My local Meineke wanted $450, that's only 50 less than I paid for the car.
9193CapriXR2
« Reply #4 on: October 30, 2023, 12:42:49 PM »
i am piecing mine together from random parts.  Using Stainless steel pipe, magnaflow high flow cat #2000124.  Cherry bomb 87521CB muffler etc.  Going to be a very short exhaust dumping behind passenger front tire.  I MAY run it back to the front of passenger rear tire if exhaust fumes become a problem.
« Reply #5 on: October 31, 2023, 12:31:37 PM »
I use 2.25D system with a turbo muffler. I believe my exhaust man said the down pipe and cat were 2.25D but sized down for the stock.system.
