Author Topic: Main relay testing  (Read 4046 times)
Gman
    • 91 Capri, 04 Suburban, 11 Suzuki SX4 Sportback
Main relay testing
« on: September 06, 2023, 09:22:26 PM »
Not getting fuel to the cylinders. Fuel pump working fine. Searched the forum and read to check the relay. What is the best way to check the relay? I found new and used relay on eBay. I want to check before I spend money on one.
Re: Main relay testing
« Reply #1 on: September 07, 2023, 09:56:32 AM »
My first one had that problem when I got it. Turned out to be a broken wire in the harness under the battery, simple fix.
