Author Topic: Crank doesn’t spin Oil pump  (Read 592 times)
CapriManxr2
    • 1991 Capri XR2
« on: May 03, 2024, 02:54:33 PM »
So I just finished rebuilding my motor not too long ago and in the first startup I noticed it was making no oil pressure. I took apart the oil pump and found that the crank was too small to spin the oil pump. So I bought a new pump thinking that would solve the problem, I bought the Melling pump off rockauto and it still does the same thing, crank is too small to spin the pump. I measured it out with a dial caliper and the flats on my crank measure 1.22” and my oil pump is 1.48”. What are your guy’s thoughts? Do I have an aftermarket crank or some sort of modified crank? See measurements below. https://imgur.com/a/JiKKkel
Re: Crank doesn’t spin Oil pump
« Reply #1 on: May 04, 2024, 08:27:27 AM »
If memory serves correct, the early ('91, early 92) have what's call small nose. The later ones have a large crank. I've never measured them but that may be what your are seeing.
CapriManxr2
    • 1991 Capri XR2
« Reply #2 on: May 04, 2024, 10:15:29 AM »
So I just did a little bit of research and yeah, I have the small nose crank. Where do I go to get an oil pump that fits? I’ve already ordered two new ones from eBay and rockauto and neither of them fit.
« Reply #3 on: May 05, 2024, 05:52:04 AM »
Oh my goodness, I remember this problem from my rebuild now. So I re-used my OEM oil pump, because I was poor when I did my rebuild and the replacement pumps are expensive. As far as replacements, I was only ever able to find two options. You could go with an OEM Mazda pump from the 90-91 Miata, if you can find it. https://treasurecoastmiata.com/i-23790246-new-oem-90-91-mazda-miata-short-nose-oil-pump-b660-14-100e.html The other option is from a company called Boundary, who makes a high flow pump for the B6 w/short nose crank. https://boundarypumps.com/shop/mazda/1-8l-bp-mazda/bp-1-6l-small-nose-crank-high-flow-billet-oil-pump/
They are both expensive, the aftermarket one significantly so. The Mazda one is a large pain in the ass to find. Whichever one you go with, buy a couple of OEM Mazda front main seals. They suck ass to install properly - I need to drop my oil pan at some point because mines leaking pretty good.
CapriManxr2
    • 1991 Capri XR2
« Reply #4 on: May 06, 2024, 10:49:07 AM »
So I ordered the oil pump for a 1990 Miata off of rockauto for $70, it comes in tomorrow and I’ll keep you guys posted if it works or not. Really hoping it works because this is all that’s left to get my capri up and running again after the motor rebuild. (Part link) https://www.rockauto.com/en/catalog/mazda,1990,mx-5+miata,1.6l+l4,1190876,engine,oil+pump,5564
« Reply #5 on: May 07, 2024, 05:12:06 PM »
They look right, but you never know for sure until you have the part in hand. Good luck
CapriManxr2
    • 1991 Capri XR2
« Reply #6 on: May 07, 2024, 08:32:40 PM »
So the part came in today and to no one’s surprise, it didn’t fit :D, I’m just gonna have to keep trying oil pumps and returning them as I go or maybe source a used one from a junkyard or find someone on EBay that will measure the pump for me before I buy it.
« Reply #7 on: May 08, 2024, 09:44:45 AM »
Good luck
« Reply #8 on: May 09, 2024, 05:34:59 AM »
Just to forewarn you, I played this exact same game with both fuel pumps and radiators. I have 4 brand new fuel pumps that don't fit, and the 33 year old OEM one still in the car. I also have 1 brand new radiator that was too long, though I did eventually source an aftermarket replacement that fit after minor modification. Rear brake calipers are gone too, so treat yours like treasure. Oh, one of the styles of alternators is also gone, as is most of the supply of parts to rebuild it. If you have a short nose XR2, you probably have this alternator.
« Reply #9 on: May 09, 2024, 01:47:11 PM »
If you take your rear calipers to Advance Auto, for the time being, they will send them off to have them rebuilt and returned.
« Reply #10 on: May 09, 2024, 09:05:41 PM »
MELLING M141 should be the oil pump you need for the small nose crank. It's listed on RockAuto for the 1990 Mazda Miata
Click the part # in the listing you can see it is for the late 80s up to 91s mazda engines. They changed the crank/pump part way through 1990 mfg date IIRC
