Author Topic: Fog light relay location  (Read 12552 times)
Snigalfriz
    • 1991 NA Capri
« on: September 20, 2011, 04:00:00 AM »
Folks,
Anyone have a pic of the location.  I don't see the socket, on my 1991, where a wiring diagram says it should be, any help would be appreciated.
1991 Mercury Capri 5-sp
1992 Mercury Capri 5-sp swap
1999 Ford Contour SE 24v v6
2003 Lincoln LS
2007 Saturn Outlook XE AWD
2014 Chevy Cruze LT
« Reply #1 on: September 20, 2011, 04:08:00 AM »
The relay mounts to the firewall near the windshield wiper motor. The harness/pigtail shouldn't be too far off from there
Snigalfriz
    • 1991 NA Capri
« Reply #2 on: September 20, 2011, 04:30:00 AM »
That's what I was seeing on the diagram, but wasn't seeing when I looked under the hood.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
« Reply #3 on: September 20, 2011, 04:31:00 AM »
Is it a 4-wire harness?
2003 Lincoln LS
2014 Chevy Cruze LT
« Reply #4 on: September 20, 2011, 04:39:00 AM »
Yes. I looked through my pics, I don't have a good shot of it. It mounts just to the left of the wiper motor.
Heres a pic of Josh's car from the first Northeast Meet - you can see the foglight relay in it, it's the black block near the wiper motor:
I might be able to get a better pic if you need one
Snigalfriz
    • 1991 NA Capri
« Reply #5 on: September 20, 2011, 05:22:00 AM »
Thanks.  I will see if I find a similar relay/socket in that location.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
« Reply #6 on: September 21, 2011, 03:36:00 AM »
Thanks, I found the relay socket, it wasn't mounted.  The socket and wire were tucked behind/under the brake master cylinder.
I am going to use a touch switch and an aftermarket relay to run the fog lights.
2003 Lincoln LS
2014 Chevy Cruze LT
Snigalfriz
    • 1991 NA Capri
« Reply #7 on: September 25, 2011, 04:37:00 PM »
Replaced the old socket with a new aftermarket socket and relay, working like a charm.
2003 Lincoln LS
2014 Chevy Cruze LT
mr_gr1mm
Re: Fog light relay location
« Reply #8 on: March 17, 2023, 09:34:14 PM »
I came across this thread the other day - I know it's old but can someone please tell me what those parts are in the pic used to replace the intake and O2 sensor box? I want to do a CAI just like this but have no idea where to begin. Did this come as a kit? I also had no idea there are compatible aftermarket O2 sensors for this car. Sorry for my ignorance but I know nothing about interfacing aftermarket sensors to such an old PCM. Thanks!
« Reply #9 on: March 18, 2023, 07:40:10 PM »
I'm not sure what you're referring to, the O2 sensor is mounted in the exhaust manifold. Are you thinking the VAF / MAF (vane AirFlow meter / Mass AirFlow sensor)?
The factory VAF is still there, there's an adapter on it to fit the cone filter. The stock J pipe is replaced with some plumbing/sewer fittings I believe.
There's no easy way to replace that sensor on this car, only reasonable way to do it is to go with a full aftermarket ECU that runs a more modern air metering scheme
mr_gr1mm
« Reply #10 on: March 19, 2023, 12:31:49 AM »
Yes my apologies, I am talking intake here. If I take a closer look at the pic it does seem like the stock MAF box is still in there. I was hoping maybe someone found a way to ditch that bulky thing, and the blue wiring kinda threw me so I thought perhaps this was an example of an aftermarket sensor.
« Reply #11 on: March 19, 2023, 04:06:39 PM »
Yes - without going through some extreme effort there's no way to remove that. No upgrades, either.
It's not a terrible thing, while unsightly it does offer flexibility with the stock fueling system, IE more air = more fuel (some limitations apply lol)
