Pages: 1 ... 30 31 [32] 33 34 ... 36
Author Topic: What did you do to your Capri today?  (Read 239506 times)
« Reply #465 on: August 24, 2020, 06:56:39 PM »
that's interesting Jack....what did you use and would you recommend it?  I need to dye some worn areas on the driver side leather seat of my 94 xr2.
It is some dye I got from a company in SC. They do standard colors for European cars and will do custom colors. You would probably need to dye the entire seat. Clean it and sand it with 400, then you can brush or spray for the same results.  Time will tell how long lasting it is. I used it on the SLK seats I put in my white car.
JimmyGermany
    • 1993 Capri non-turbo
« Reply #466 on: September 06, 2020, 06:06:08 AM »
Slowly getting things ready for hibernation.
Back / Side position lights removed and replaced with cleaner used parts. Screws and clips replaced with stainless steel parts.
After much cursing - front left blinker replaced with cleaner used parts. Right one is up on my next days off.
Looking forawrd to next summer!
Cheers
James
JimmyGermany
« Reply #467 on: September 22, 2020, 05:13:14 PM »
Attached rubber edges to the metal trunk “floor” (which replaced soggy pressboard one) - since rubber edging left over, attached to trailing edge of doors to reduce rubbing and rattling. Began electrical trouble shoot by charging battery fully with charger.
Casper
« Reply #468 on: September 27, 2020, 04:06:04 AM »
Well I am still going with a head gasket fix - my poor 91 turbo overheated while racing a couple of months ago when the fan belt broke and bent the head  - cylinder head has been repaired (including welding a crack in cylinder 1 exhaust valve part of head) and now the journey continues - water pump, timing belt, new gaskets all round - and cleaning of most things in between....I just have to make a crank bolt tool to remove it so I can get the new belt on....(thanks to this forum as fixing most things would be hard without everyone's knowledge available)......
JimmyGermany
« Reply #469 on: October 09, 2020, 09:48:06 AM »
Reassembled shifter linkage using CorkSport bronze bushings.
Tested hardtop wiring before proceeding with repairs to fabric.
« Reply #470 on: October 09, 2020, 10:24:43 AM »
Went on a wonderful ride though the mountains, enjoying this Indian summer.
redsteve
« Reply #471 on: October 09, 2020, 04:26:22 PM »
Sigh...wished I could do what Jack did today, it would be perfect for that today.
Except my mountains have been on fire for eight weeks.
I'm glad one of us is enjoying the ride....if not me, my friends!
Cheers all,
Steve
« Reply #472 on: October 10, 2020, 10:53:31 AM »
Cheers all,
Steve
Sorry to hear that, I've been though those forests and they are/were beautiful.  Stay safe.
« Reply #473 on: October 12, 2020, 11:59:20 AM »
Put a new Optima in my white car today. Had been having cranking problems and it finally stopped cranking.  Battery tested good, but it wasn't.  That's the third time I've experienced that.
redsteve
« Reply #474 on: October 13, 2020, 12:43:14 PM »
Jack, thank you.
We're back from mandatory evacuation so today I hope to dig my old girl out for a short spin in the semi-warm, semi-smoky fall weather.
Yaaay!
Steve
« Reply #475 on: October 14, 2020, 10:08:09 AM »
Jack, thank you.
Yaaay!
Steve
You go buddy.  Thank goodness
Tomfromparma
    • 1992 XR2
« Reply #476 on: October 23, 2020, 02:12:49 PM »
Today I dropped the kid off at school and replaced the trunk struts for my xr2. Now, I turn the key and it pops all the way open. Nice sunny day for a drive too.
redsteve
« Reply #477 on: November 02, 2020, 12:13:49 PM »
I'm about to drive down the mountain with the top down, it's just kinda sorta warm enough out here to do that.
I should drive the truck down to get lumber and other project supplies, but...
Cheers all!
Steve
redsteve
« Reply #478 on: December 09, 2020, 05:27:48 PM »
Hi all,
Today it was 50 something up here so I went for a drive, top down and stereo up. The sun was sliding behind the mountains on the way home....brrrrrrr.
It's to snow on and off through Monday so I figured I just had to get out today.
All I need is four and a half miles and I've put a thousand on it this year!
Cheers,
Steve
« Reply #479 on: December 10, 2020, 07:43:21 AM »
Hi all,
Cheers,
Steve
You go Steve.
