Author Topic: silly question - how to remove boot spoiler  (Read 5964 times)
Rickster
« on: May 22, 2008, 12:38:00 AM »
Hi,
I'm a bit of a mechanical novice and have recently purhcased a 1990 SA Turbo.  I need to remove the rear boot (trunk) lid spoiler for painting, but can't work out how to get it off.
I've removed a couple of rubber grommets from under the boot lid but can't see any fasteners.
Can someone please point me in the right direction?
Thanks
« Reply #1 on: May 22, 2008, 08:03:00 PM »
Rickster-
There are 6 bolts that you need to remove, I believe they are 8mm, although they could be 10mm (I don't remember!).  Unless someone beats me to it, I can post pictures tomorrow night of their locations.
I know this isn't much help, but I do not have a Capri nearby!
Again, I'll post detailed pics tomorrow night of the locations!
« Reply #2 on: May 22, 2008, 08:45:00 PM »
there are access holes thru the trunk lid frame, there are three on each side where the spoiler mounts. I think two of them are kinda tough to get at
Rickster
« Reply #3 on: May 22, 2008, 09:01:00 PM »
Thanks very much for the replies guys.  Will have another look but would really appreciate the pics Russ when you have a chance
cheers
« Reply #4 on: May 23, 2008, 08:30:00 PM »
Rickster-
As promised, here are the pics.  two are of the outside of the boot lid, just to help you position them. The last two are from the inside of the lid:
Hope this helps!!
Rickster
« Reply #5 on: May 24, 2008, 01:10:00 AM »
Wow!!! Thanks Russ for going to all that trouble.  That definately helps and should get me out of trouble - I had no idea how they were set out.
Very much appreciated
Rickster
« Reply #6 on: May 24, 2008, 06:03:00 AM »
No trouble at all!!  I've gotten so much help from this forum, that any chance i have to return the favor, I do!
Good luck with your project!
Rickster
« Reply #7 on: May 25, 2008, 08:39:00 PM »
Thanks Russ - will post some pics when I get a chance. @ of the bolts on each side of the spoiler were philips head and came out easily. But one on each side looks like a back the front threaded bolt with a slot in the bottom. Can't get those damn things out yet. THey are stuck fast and not sure which way they turn. I checked our other Capri and it has exactly the same ones. Aaaah! - will get it eventually
Love your website by the way  - the cars are awesome - you're a lucky boy to have so many!
« Reply #8 on: May 26, 2008, 06:53:00 AM »
Sounds like a previous owner swapped bolts, or Ford used different fasteners for AU-spec cars.
You call me lucky for having so many(we have 14 now)-everyone else calls it crazy!!
« Reply #9 on: May 26, 2008, 06:24:00 PM »
Hey Russ! Nice to hear I'm not the only "NUT". When my roomate talks to her friends about me and my Capris, the words Nut and Crazy are usually very prominent in the conversation.  Gus.
STE_6000
    • http://teamcapri.com
« Reply #10 on: May 27, 2008, 12:30:00 PM »
wel u are conversating with russ. -_^
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
« Reply #11 on: May 27, 2008, 07:34:00 PM »
OOOOOOOOOhhhhhh  - What, exactly, are ya trying to say, Anthony???
STE_6000
« Reply #12 on: May 28, 2008, 01:16:00 AM »
I ain't said nuttin.  ;)
Anthony
-Tinted Windows 20%
-Corsa Exhaust
