Author Topic: 1991 inner ignitor module  (Read 3718 times)
cap-ri
« on: December 19, 2011, 05:01:00 PM »
Do i need any special tools for this job?  I am looking at replacing the inner ignitor module on my dual vac diaphram distributor.  FYI B6VD is stamped on the distributor.   As far as I know I just remove the cap, rotor, gasket, cover and then im there.
« Reply #1 on: December 19, 2011, 06:13:00 PM »
You'll need a 2 or 3-jaw gear puller to remove the armature from the shaft to get further inside the assembly. There's a write-up on the Yahoo! group, not sure how accurate it is though.
Try this link: http://f1.grp.yahoofs.com/v1/YCTwTmtZRY2KU5TK8HrE5IiXVI9BldJC76wKuzM-4z-0fiH5vB8UgthlogUKz-iZobVX1fttDlx6XC5S8ol9GCdoXN3BAYF2xKlKYwrhEw/Capri_HOW-TO_Igniter_Module_Replacement.pdf
Otherwise you might have to join to see it
cap-ri
« Reply #2 on: December 20, 2011, 02:28:00 PM »
Thanks rocketman.  I found a good deal on a used distributor today and I will be installing the whole unit instead.
Any tips on reinstalling the distributor?
« Reply #3 on: December 20, 2011, 02:34:00 PM »
Replace the o-ring, you'll regret it later if you don't.
Replacing it is very straightforward. Remember to re-set your ignition timing when done
