Author Topic: 91 capri base model  (Read 3313 times)
todd williams
    • 91 capri base model
91 capri base model
« on: April 30, 2015, 07:58:00 AM »
I have a 91 capri base model without sway bars. it is starting to sway or float more and more, almost feels like you are in a boat. And it feels like its coming from the rear.
What can it be?
Re: 91 capri base model
« Reply #1 on: April 30, 2015, 11:49:42 PM »
Worn struts, bushings, bearings. Old tires.
Swaybars help keep the car flatter and more stable around corners, but if it feels like boat you have something else going on
todd williams
« Reply #2 on: May 01, 2015, 02:15:06 PM »
I put brand new tires on it. the old ones wore out evenly. I did change the outer bearings as they were bad. Could the inner bearings be causing this?
