Author Topic: Need distributer wiring pics  (Read 5795 times)
Teamreedracing
    • 92 capri 06 trailblazer 94 s10 03 honda 00 gmc
« on: March 03, 2017, 03:45:02 PM »
Can someone please take some pictures of the distributor wiring rabbits chewed my wiring and I need pics so I can rewire it here's my # 307-277-8332 u can text them to me
Re: Need distributer wiring pics
« Reply #1 on: March 03, 2017, 05:30:52 PM »
Ill post engine bay pictures, aswell as a wiring guide. Give me a day or so im in the process of moving, so the only time I have to get on TeamCapri is while at work.
Teamreedracing
« Reply #2 on: March 03, 2017, 07:32:52 PM »
Thank you
« Reply #3 on: March 03, 2017, 08:10:17 PM »
Are you looking only for the dizzy wiring or the whole starting harness?
Teamreedracing
« Reply #4 on: March 03, 2017, 08:35:50 PM »
The whole starting harness
« Reply #5 on: March 04, 2017, 01:50:56 PM »
I havent forgot you, im having a rough time finding a diagram that shows not just a wiring guide, but the engine itself. Im going to keep looking.
Teamreedracing
« Reply #6 on: March 04, 2017, 01:52:52 PM »
No problem thanks again
« Reply #8 on: March 04, 2017, 04:20:20 PM »
There are full-car wiring diagrams on Tech Capri and my Werbatfik mirror of TechCapri
http://www.techcapri.com/Wiring.html
« Reply #10 on: March 04, 2017, 09:40:53 PM »
It should work, the only major difference to the 94s is the new passenger airbag. Im almost certain that the engine remained untouched, but I could be wrong someone like Chrispoe/AZGTX/Rocketman would know if it would be exact.
Teamreedracing
« Reply #11 on: March 04, 2017, 10:05:59 PM »
Rocketman says there's some differences in the harnesses he said to find one from 91-93
« Reply #12 on: March 04, 2017, 10:10:26 PM »
Ah okay, have you tried calling Roo-Sport? He should have a N/A harness you can buy. The website i Roo-sport.com the phone number should be on the front page.
Teamreedracing
« Reply #13 on: March 05, 2017, 12:49:11 PM »
Is there a way to test the ignition control module in the distributor
« Last Edit: March 05, 2017, 03:28:14 PM by Teamreedracing »
« Reply #14 on: March 05, 2017, 02:47:53 PM »
Would have posted yesterday, but I didn’t get home from the auto show until almost 2AM.
The wiring to the distributor on N/A’s is pretty simple.
The engine harness 4 wire plug-----distributor side wiring
Black/white stripe= 12V ignition power------Black/white stripe splices to all components
Yellow/blue stripe= Tach signal------ Larger blue wire going into ignition module inside
Black= CID - signal------Black wire going to external CID sensor
Yellow=CID + signal-----Red wire going to external CID sensor
Single wire plug:
Green/yellow stripe=barometric ignition advance-----Smaller blue wire going to ignition module inside
« Last Edit: March 05, 2017, 03:39:12 PM by chrispoe »
