Author Topic: Engine Available?  (Read 2456 times)
jimmy1439
Engine Available?
« on: April 04, 2011, 12:04:00 PM »
I am wondering if anybody might know where an engine might be hanging around, needing a home?  I would like to get one that needs rebuilding and do it at my leisure.  The engine that is in mine ('94 N/A) burns some oil and I would like to do the rebuild while still driving mine.  I am fairly certain that mine needs rings since I have done just about everything else to it.
Also, I have another thread asking about swapping a turbo engine into mine.  I do not know how difficult this is, but I suppose this would be a good time to pick that up if it is a swap that is possible.
Thanks in advance for any help.
Jim
Engine Available?
« Reply #1 on: April 04, 2011, 12:09:00 PM »
To do a turbo swap right, you'll want a whole donor car.
The easiest route, is to go find an XR2 to drive.
The turbo swap is not as much a swap as it is a conversion, you can swap in just motor/harness but then your stuck with a ticking timebomb of a transmission. (turbo has beefier trans, larger better clutch)
If you'd like I can go into detail about the conversion.
I'm not sure where you could find a motor, there seem to be a handful floating around
jimmy1439
Engine Available?
« Reply #2 on: April 04, 2011, 12:17:00 PM »
Hmmm, that takes care of that.  I'll just keep my eye out for a decent XR2 when I have enough money sitting around.
OK, now to narrow the search then...Does anybody have an extra engine sitting around that needs to be rebuilt before using?
Engine Available?
« Reply #3 on: April 04, 2011, 02:58:00 PM »
I have a couple of engines laying around. Some need a good going over/rebuild.
Feel free to email me: CapriTypeR@Gmail.com, or give me a call: 847-370-3760
