Author Topic: Can anyone tell me what these are?  (Read 7380 times)
bhazard
« on: April 02, 2010, 03:07:00 AM »
What are each of these? And which are required to run? I know the Capri had an electronic boost gauge sender and overboost sensor. I just don't know whats what. Also where do the vac lines go?
And can I get away without a purge canister and solenoid?
Ive been told 1 and 2 are overboost and baro, both required (for now). Is 3 the boost gauge sender? I think 6 and 7 are purge solenoids, both the Capri and festivas. Can I ditch them?
Heavensheros
« Reply #1 on: April 02, 2010, 03:48:00 AM »
ive ditched the fuel pressure regulator boost gauge and over boost gauge
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
bhazard
« Reply #2 on: April 02, 2010, 03:53:00 AM »
Which ones for the pressure regulator?
Gotta keep the overboost sensor for now.
Heavensheros
« Reply #3 on: April 02, 2010, 05:46:00 AM »
boost gauge is 1 and the regulator is next to number 2 with 2 vacuum hoses going to it ... i think you should keep it because rocket man said it helps with hot day restarts or something i bypassed mine because i broke the plastic nipple :-/
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #4 on: April 02, 2010, 03:16:00 PM »
#1 is the overboost sensor. Looks like its been mounted differently?
#2 is the base baromentric pressure sensor for the ECU
#3 is the boost gauge sensor
#4 looks like a relay? Can't really tell.
#5 is the FPR solenoid. It closes on a hot start to increase fuel pressure to keep boiling fuel out of the fuel rail
#6 is the canister purge solenoid.
#7 i'm not sure off the top of my head
looks like your solenoids / vac lines have been messed with quite a bit
« Reply #5 on: April 02, 2010, 03:49:00 PM »
anything that connects to the canister normally can be removed and plugged if you dont need emissions
bhazard
« Reply #6 on: April 02, 2010, 04:06:00 PM »
Quote
Well, this IS a festiva were looking at here...  ;)
I guess 7 is also a purge solenoid, the festivas.
If 5 is the FPR relay shouldnt it have two vac lines? One to manifold vac/boost and one to the FPR?
« Reply #7 on: April 02, 2010, 04:16:00 PM »
Yeah, if you look 5 isn't connected to anything, looks like the line is just looped. Does have 2 connections on it though
Its not a super critical part, I ran without one for a while, the early JDM motors didn't use one at all
bhazard
« Reply #8 on: April 02, 2010, 04:23:00 PM »
Well it looks like I will be able to simplify things a bit then. No boost gauge sender and no purge solenoids. I thought about keeping the evap but as long as Im not loosing gallons of gas out of that hose I'm okay.
Hopefully someday I'll be able to afford to get rid of that overboost sensor too
J. D.
« Reply #9 on: April 15, 2010, 04:05:00 AM »
So what happens if the overboost sensor "breaks" while running a stock turbo/ECU?  Also, hi everyone.  I was here for like a week a few months back, and now I'm here again...
« Reply #10 on: April 15, 2010, 04:10:00 AM »
Hi JD.
If you're running stock boost & have a stock exhaust you should be okay, just keep an eye on the boost gauge. If you're seeing 10+ lbs then might be a good idea to get things straightened out.
If you want to replace it, I'm sure someone is willing to offer theirs up, and theres also adjustable Hobbs pressure switches you could install.
How did yours "break"?
STE_6000
    • http://teamcapri.com
« Reply #11 on: April 15, 2010, 04:27:00 AM »
#4 looks like the relay for the fog lights.
Anthony
-Tinted Windows 20%
-Volant Cold Air Intake
-Corsa Exhaust
J. D.
« Reply #12 on: April 15, 2010, 09:36:00 AM »
Rocket, it didn't break.  I was wondering if it was safe to unplug.  But the real issue is that I DON'T pay attention to my boost guage, and therefore, entering the highway in 4th can be scary if I'm not prepared for it, so I should probably leave it.  I'm planning on picking up a rocketchip this spring if funds allow, it's really that annoying.  I was just curious.  Thanks
« Reply #13 on: April 15, 2010, 10:25:00 AM »
Gotcha. Its there for a reason.
Why not run an aftermarket gauge on the a-pillar? A lot easier to keep track of.
J. D.
« Reply #14 on: April 15, 2010, 12:06:00 PM »
Not actually that worried about it...just annoys me sometimes.  Like I said, I'm hoping to order one of your rocketchips in a couple months, if you're still making them.  Also, would a turbocoupe turbo fit under the hood without much extra stuff?
