Author Topic: What is this?  (Read 2610 times)
What is this?
« on: April 11, 2009, 04:25:00 PM »
i had the car up on a lift today to change the tranny fluid and i saw there a sensor above and to the left of the oil filter was leaking. what sensor is it? it was behind the bracket that connects to the the intake manifold and starter....
on another note the stupid tab broke off the speedo cable. do you think the cable will stay in with out it? i guess i need to find one now. i drove it home fine it was pretty snug to put it in so i hope it stays in for a while.
What is this?
« Reply #1 on: April 12, 2009, 07:19:00 AM »
ANYONE?
What is this?
« Reply #2 on: April 12, 2009, 07:57:00 AM »
http://www.werbatfik.com/img/capriwork/capriwork82.jpg
Knock sensor or oil pressure sender? knock is up front
and FWIW, the tabs break on nearly every capri i've worked with. I kind of just gently bolt the broken tab back down to hold the speedo in place. It will work its way out over time if you dont find a way to hold it down, I've had it happen.
What is this?
« Reply #3 on: April 12, 2009, 03:12:00 PM »
its the one with the yellow wire..the bigger one..which is that?
What is this?
« Reply #4 on: April 12, 2009, 05:41:00 PM »
oil pressure sender
What is this?
« Reply #5 on: April 13, 2009, 01:16:00 AM »
thanks...guess i be changing that on the next oil change too
