Author Topic: How to install my new boost controller  (Read 3307 times)
randyshear
    • http://www.a1title-42.com
« on: June 19, 2009, 05:43:00 PM »
I got the a/f meter, and intKe, now how do I install the mbc on my car?
-Randy Shear
« Reply #1 on: June 19, 2009, 07:38:00 PM »
It installs on the boost source line to the wastegate from the intake crossover pipe
moot
    • http://www.cardomain.com/ride/3338493
« Reply #2 on: June 19, 2009, 08:14:00 PM »
i got the ecu rocket thanks man
gotta get a mbc just got my bank acount set up so i can buy stuff online
« Reply #3 on: June 20, 2009, 06:54:00 AM »
here is a diagram
Directions for installing a manual boost controller (MBC)
   1. Remove old restricter pill lines that connect the wastegate to the turbo outlet vac port.
   2. Disconnect original OEM electric boost controller sensor line.
   3. Take the extra line removed and connect it to either side of your new MBC.
   4. Connect the exit port of the MBC to the turbo inlet vac port.
   5. Connect the entrace to port of the MBC to the wastegate vac port.
   6. Mount MBC anywhere you please, close is better because less chance of a leak.
   7. Adjust MBC according to manufacturers directions how many PSI you want to increase, or decrease.
« Reply #4 on: June 20, 2009, 06:55:00 AM »
oh ya and on our cars you need to electrically disconnect the sensor to raist the boost past 10 i believe
« Reply #5 on: June 20, 2009, 06:40:00 PM »
its 12 ...but yea you must disconnect the overboost switch ( on the firewall, its round and has a white connector below it, and a vaccume line connected to it....remove it completely...)
those units are pretty cool little rigs... there essentially a boost activated switch, preset for 12 psi.... you can basically use it to controll anything you want to come on at 12psi...
IE.. nitrous or water meth.....cool huh
    Joe .....
« Reply #6 on: June 20, 2009, 06:41:00 PM »
    Joe .....
Yuri
« Reply #7 on: June 20, 2009, 06:57:00 PM »
mmmmm nitrous
randyshear
« Reply #8 on: June 23, 2009, 06:53:00 AM »
Ghost the diagram didnt show up. Can I get another one? I disconnected the overboost plug, (am I supposed to unhook the vacuume line from it too?) cut the line going from my wastegate to the intake, and installed my MBC between it. (One line going to the intake, the other going to the wastegate.) Is this correct?
-Randy Shear
