Author Topic: Air Bag System Removal?  (Read 8445 times)
« on: May 16, 2009, 05:20:00 AM »
Anyone in the states removed the air bag system yet to install an aftermarket wheel?
i been really thinking about it. just not sure what adapter will work
JackRobot
« Reply #1 on: May 16, 2009, 06:02:00 AM »
Mines already half out, I have my steering column ripped apart, The option I'm going with is a weld on quick removal hub, From what I found, there are no bolt on kits.
Also, it seems removal of the air bag system in the us is illegal, so uh, my capri didn't have airbags? lol   :rolleyes:
The only problem I can think of, is if the car will still run without the system hooked up, I hope so anyway.
« Reply #2 on: May 16, 2009, 11:57:00 AM »
i see people driving all the time with duct tape covering the bag location..LOL so i am sure it will drive.
can you take a photo with the wheel off i want to see the bolt. i am sure something have to mount in there. i wish i could weld damit!
Heavensheros
« Reply #3 on: May 16, 2009, 05:55:00 PM »
the car will run, i ran my car withough an air bag in all that happens is the air bag light will constantly flash.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
JackRobot
« Reply #4 on: May 16, 2009, 08:25:00 PM »
I'm removing everything, so I shouldn't have any problem with the light, It will be gone as well hah.
I'm going to look into some hub adapters some more, but I don't think I'll find anything.
I'll keep you guys updated.
« Reply #5 on: May 17, 2009, 04:55:00 AM »
there has to be some kind that will work. at least one that is a little bigger that u could weld in
JackRobot
« Reply #6 on: May 19, 2009, 09:32:00 PM »
Here's the setup I'm using.
Painted black
« Reply #7 on: May 20, 2009, 11:13:00 AM »
Dude, I need to know where you got that.. So it bolts on?
JackRobot
« Reply #8 on: May 20, 2009, 12:01:00 PM »
The splined shaft, is welded onto the steering column shaft. the rest bolts onto the quick release.   :cool:
JackRobot
« Reply #9 on: May 22, 2009, 12:12:00 PM »
Should have my quick release tomorrow, so I should have an update asap.
« Reply #10 on: May 23, 2009, 06:42:00 AM »
when you start tearing the srs out thare is also a chime that will beep 5 times over and over
it will drive you crasy if you dont take everything out.. the beeper itself is located somewhere near the fuses under the dash on the drivers side.. ive removed the sensors and unplugged the box in front of the shifter under the center console and it quit beeping
thare are 3 sensors (black box aprox.4in x 4in)
in the front under the handy shelf our cars have between the headlights.. behind the bumper..
as far as the airbag removal itself i havent got there yet. just the sensors. when i removed the bumpers front and rear to drop more weight...
JackRobot
« Reply #11 on: May 23, 2009, 10:04:00 AM »
Yeah, I'm removing everything associated with the air bag system. I got my quick release today, already have it mocked up, pics soon!
« Reply #12 on: May 23, 2009, 10:20:00 AM »
i might give it a go when i see your jack...i did just sell my momo wheel but i want one to go with my color theme of red...
JackRobot
« Reply #13 on: May 23, 2009, 10:46:00 AM »
I like this style the guy I bought my wheel from sells. would fit your interior nice.
http://cgi.ebay.com/ebaymotors/GTR-POWER-RED-F-1-Sports-RACING-STEERING-WHEEL_W0QQitemZ130308011141QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item1e56f67485&_trksid  =p3911.c0.m14&_trkparms=72%3A1205|66%3A1|65%3A12|39%3A1|240%3A1318
Here's some pics, I kinda guessed and ordered the 3/4 knowing I could return it if it didn't fit, but low and behold it is a perfect fit, straight on with no gaps should be rock solid once its welded. Very happy with this setup, should work out well.
Once its welded and painted so its not purple. I can reassemble the column and we'll see how well it works. I'll take a pic once my steering wheel gets here.    :cool:
JackRobot
« Reply #14 on: May 24, 2009, 05:29:00 AM »
One problem, the stock key ignition setup gets in the way of the quick release, I'm going to use a dash mounted key and push button start.
