Author Topic: Na Hubs/Brakes same at XR2  (Read 2345 times)
« on: June 19, 2010, 04:07:00 AM »
are the hubs and brakes the same? could they be swapped out or no go....?
« Reply #1 on: June 19, 2010, 06:18:00 AM »
If the brake rotors are the same size then yes. NA's sometimes came equipped with much smaller rotors than the XR2 brakes
« Reply #2 on: June 20, 2010, 08:34:00 AM »
i think his is the large ones..installed the ones it called for from the shop and they look small and not filling in t he whole brake pad...
« Reply #3 on: June 20, 2010, 08:46:00 AM »
Yeah, If the pads overhang the rotors by ~.25" then is uses the large rotors, "XR2 size" I have a set laying around somewhere
I've seen it done before, it caused severe stress on the rotor inducing cracking, and since a large portion of the pad does not wear at some point the two pads will contact and BAM no more brakes...really dangerous.
Also, I can't imagine braking would be all that great because the swept area is reduced dramatically
drbob
« Reply #4 on: June 20, 2010, 09:52:00 AM »
Quick question again on brakes, my 94 uses xr2 rotors and n/a pads?  Or are they both xr2?
AUSTRALIAN Shepherd
« Reply #5 on: June 20, 2010, 01:18:00 PM »
Should be XR2 pads as well.
