Classifieds => Capri Parts => Topic started by: NomakeWan on February 05, 2017, 04:52:58 AM
Hey all, I'm looking for new oil and coolant lines, both the rubber and hard lines and associated bolts and crush washers. Anybody got some laying around? I'm running the VJ11/14 hybrid with the VJ14 CHRA, so the stock VJ14 lines are fine by me. Thanks!
I should have the hard lines, and maybe a few crush washers, but you'd be best to obtain new crush washers at a good auto parts store. The drain hose is a Russ only thing AFAIK or maybe the other Capri website has it also at 3x RooSport's price. I might only have the VJ11 oil drain tube spigot, since my vj14 got reused on my hybrid. Do you have the coolant hoses though? I just cut up a 1 year old s-shaped one to use for the tiny one that feeds the bypass from the t-stat. Russ has the hoses if needed.
I've got some, but I figured I'd just ask for the whole kit'n'kaboodle while I'm at it. My VJ14/11 has the spigot on it though, so at least that's good. I'll have to give Russ a call about the drain tube and such.
Are your hard lines clean and clear of debris? If so I'll take them off your hands.
A little grungy on the outside but no holes or clogs. Typical for the temp they run at..
(http://i913.photobucket.com/albums/ac337/rapidcad1/image_zpsazoc9erl.jpeg)
(http://i913.photobucket.com/albums/ac337/rapidcad1/image_zps1fxmyjkf.jpeg)
