Author Topic: Alternator issue  (Read 2101 times)
dam55
Alternator issue
« on: July 16, 2009, 09:04:00 AM »
Battery is good (load tested) cables and connections are good. Belt is good. With that said. The alternator is new X 2. Both tested good at auto shop but when on the car at charging rpm the voltage decreases and maintains at idle. Anyone have any suggestions Please!!! 1992 XR2
Alternator issue
« Reply #1 on: July 16, 2009, 01:21:00 PM »
make sure the connector polarity is correct on the alt? my guess
Alternator issue
« Reply #2 on: July 16, 2009, 01:38:00 PM »
Perhaps the battery load tests fine but isnt charging properly? How old is the battery? are the alt connections in good shape?
a97sky
Alternator issue
« Reply #3 on: August 07, 2009, 07:14:00 AM »
Also make sure all your bolts on the alternator are locked down so the belt is tight. The alternator is the tensioner for that belt. I had a similar problem a while back and realized after tightening the belt everyday that the bolts were working themselves loose because they were covered in grease from an oil leak i had. Cleaned the bolts and never had the problem again.
dam55
Alternator issue
« Reply #4 on: August 07, 2009, 08:01:00 AM »
Thank you to all who replied. I did find the problem 3 alternators later and alot of hair pulling. Ended up that the trunk cargo light switch was shorting out and caused a constant draw.  I narrowed it down by connecting a test light between the negative terminal and the battery post and pulling fuses one at a time until the light went out, then checking that circuit throughout.
Thanks again,
Darryl
