Pages: 1 2 [3]
Author Topic: installing guages  (Read 8224 times)
Heavensheros
installing guages
« Reply #30 on: July 17, 2009, 02:48:00 AM »
which one is the more accurate one the boost gauge or the stock gauge ?
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
installing guages
« Reply #31 on: July 17, 2009, 07:47:00 AM »
Nearly any aftermarket gauge will be more accurate than a stock gauge.
installing guages
« Reply #32 on: July 17, 2009, 07:55:00 PM »
i just looked at my hook up and the line that goes to the thing we disconnect has a t fitting going to another solenoid. what is that one?
installing guages
« Reply #33 on: July 18, 2009, 05:06:00 PM »
That is the boost cut switch.
installing guages
« Reply #34 on: July 18, 2009, 06:17:00 PM »
so once you install the boost controller and gauge you can eliminate both of them?
installing guages
« Reply #35 on: July 18, 2009, 06:20:00 PM »
Sorry. Missed the part about the solenoid. You do need that it goes to either the FPR or to the vapor purge canister for the gas tank.
installing guages
« Reply #36 on: July 19, 2009, 05:28:00 PM »
i need to look then how mines set up then
Colorado1
installing guages
« Reply #37 on: March 22, 2011, 02:40:00 PM »
OK-that was confusing? I just put in the boost gauge and teed it into the line just before the 90 degree nipple on the pass. side. Now is that right? Fast job so I'll have to clean it up this weekend.
Pages: 1 2 [3]
