May 08, 2024, 10:55:52 AM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Tech, Repairs, Upgrades
Capri XR-2 89-94
Beather and pcv?
« previous
next »
Pages: [
1
Print
Author
Topic: Beather and pcv? (Read 1716 times)
sterling94capri
Full Member
Beather and pcv?
on:
January 02, 2011, 03:52:00 AM »
Do I still need a PCV if I have a com cover breather or what? Mine makes a buzzing vibration sound some time,was gonna replace it but with the breather I am wondering does it do anything?Thanks Rocky
Guest
Beather and pcv?
Reply #1 on:
January 02, 2011, 06:22:00 AM »
I think that if you want it to operate properly it creates a vacuum at the pcv to suck in valve cover emissions. The valve itself is to stop anything from going back into the upper cylinder head. If it's making noise it could be damaged. Should be like $3 at a parts store.
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Beather and pcv?
Reply #2 on:
January 02, 2011, 02:56:00 PM »
Keep the PCV. The buzzing is the valve opening/closing rapidly due to crank pressure. You can run a catch can, but still need the valve inline. Pressurizing the crankcase is a good way to blow out all your oil seals.
bhazard
Sr. Member
Beather and pcv?
Reply #3 on:
January 03, 2011, 12:25:00 AM »
I put a catch can inline with the valve cover breather. Is there a more optimal setup?
Print
Pages: [
1
« previous
next »
Capri XR-2 89-94
Beather and pcv?
