Author Topic: 2.0l replacing 1.6l is it possible???  (Read 6691 times)
Moparman65
    • 1991 capri xr2
« on: May 07, 2014, 01:50:30 PM »
So I got this wild and crazy idea the other day, and I was wondering if anyone else has done, tried, failed or was succussful at this or could point me in the right direction. I want to make this car my little race car and drop a 2.0l turbo in place of the 1.6l it would jump massively in front end weight, horsepower, and compression if I did. Any ideas guys cause this capri would be something else if I could make this not just a dream but a crazy reality.
Re: 2.0l replacing 1.6l is it possible???
« Reply #1 on: May 07, 2014, 10:30:13 PM »
The 1.8 BP is a good option, and would be less work than any available 2.0L engine. I have a thread here in the Engine Swaps section regarding the finer details.
Did you have a particular 2.0L in mind, or is that just the displacement that seems good to you?
Swapping engines may not make the car more nose-heavy. Keep in mind we have an iron block. Going to one that might be all-aluminum may actually save weight.
The Ford ZETEC engine came in 1.6, 1.8, and 2.0L flavors, and the 2.0 has recently caught my eye. In some of the Ford Escort models ( the ZX2 I believe) the Zetec 2.0L came mated to a G-series transmission. While not identical to our transmissions (different shifting mechanism, bolt pattern, mounts) the axles appear to use the same inboard splinecount, which would mean you could use stock XR2 axles with it.
If that is the case, then the hardest part of swapping in a different engine in is already solved (axles!) Fabbing mounts would take some work, as would wiring with the much newer Zetec engine, but no custom axles would be needed. (this is not to say it will otherwise fit without clearancing, I don't know, yet. Even the BP swap requires some clearancing)
Zetec as far as I know is okay power-wise but responds very well to boost.
The Mazda MZR engine has been catching my eye, it's a 2.3 or 2.5L engine depending which you get, but it's nowhere near bolt-in. But makes some incredible power in n/a form. Too pricey for me to play with yet. I'm sticking with my BP for the time being, if I run across a Zetec cheap I'll consider it.
« Last Edit: May 07, 2014, 10:32:23 PM by Rocketman »
grantduffield
  • TeamCapri Supporter
    • 1991 Capri (automatic)
« Reply #2 on: May 08, 2014, 03:50:21 PM »
Purely out of curiosity, Rocketman - What models does the MZR engine appear in?
« Reply #3 on: May 08, 2014, 06:17:42 PM »
Newer Mazda models, Mazda6 etc it looks. Ford also has a flavor of it under the Duratec name
http://en.wikipedia.org/wiki/Mazda_L_engine
http://en.wikipedia.org/wiki/Duratec#Ford_global_straight-4
crshbndct
    • None till tomorrow
« Reply #4 on: May 09, 2014, 06:59:58 PM »
You might want to look into an FE3 engine. I am told it is a much easier swap than one of the newer engines, and they are built strong as hell.
Personally I think it would be easier to just play with the 1.6 though. With the right turbo (TD04HL) you can get 280HP, with boost starting to build at <2000RPM, and full boost at <3000RPM, and massive amounts of midrange, which is what you need for good performance on the street.
This is the exact setup I am going for, with a JDM B6T(only for the stronger rods and bignose crank), forged 9:1 pistons, Megasquirt ECU and a strengthened stock gearbox with an LSD. I had a drive in a fwd 323 built by my tuner to these exact specs, and it was just amazing. I believe he managed a low 13sec pass on street tyres. Obviously you need to do all the rest of the stuff like intercooler, fuel delivery, exhaust etc as well.
Despite their small size, these B6T engines are quite torquey, and it would be a lot less hassle to work with the stock engine and push it a bit harder, than it would be to transplant a new one and then still have to go through the trouble of turbocharging it which would require most of the same work anyway(ECU, Pistons, potentially rods, fuel system, manifolds, etc)
The added drivetrain shock of the bigger engine would probably just result in more broken gearboxes and smokey tires too.
« Reply #5 on: May 09, 2014, 10:32:30 PM »
I was a huge proponent of the B6T, and still am to a very large extent, but a boosted BP is just...great. So much power and torque available ALL THE TIME. The B6T will rustle your jimmies, don't get me wrong, but that extra displacement gets the goosebumps going.
Might want to check your JDM B6T. To my knowledge, they never came with stronger rods AND a large nose crank. Either way there are now inexpensive H-beam rods out there now that will be far superior to the GTX rods.
The FE3 isn't very common here in the states, it would probably be as difficult as a Zetec swap. You'd have to use a nonturbo F2 MX6 g-type trans, and source the FWD FE parts from overseas (we did not get FE3 stateside, had a watered down version in the Kia Sportage) The FE is longer than the BP, and the BP needs clearancing to fit as it is. It'd be a hassle. Look at the aftermarkets, too (not that I'm trying to discourage an FE swap!)
crshbndct
« Reply #6 on: May 10, 2014, 05:04:12 AM »
Oh yeah I am taking the engine with the better rods and putting the crank into it. I decided to do it this way rather than pull my existing one and have the car off the road, and the engine was cheap.
I know what you mean about the bigger engine being better, but I have generally been of the opinion that engine swaps are what you look into when you start reaching the reasonable power potential of the engine you already have.
I would vote for the BP engine as well, since it is a relatively much easier swap, and already comes turboed.
