Author Topic: Shifter Lever bushing  (Read 4835 times)
tellerx
« on: August 28, 2009, 12:29:00 PM »
Hey people I was trying to find out where to order the shifter bushing that causes the shifter lever to fall when it wears out looked all over and can't seem to find who sells this part
« Reply #1 on: August 28, 2009, 01:22:00 PM »
Hey Tellrx!  I believe that part is NLA(no longer available) You have to check wrecking yards or perform one of several types of quick fixes.  Gus
« Reply #2 on: August 28, 2009, 02:39:00 PM »
Go to a Mazda dealer and order the part for a 88-89 323 GT dohc turbo front wheel drive if you have an xr2. I have taken the xr2 shifter and used it in a turbo 323. Not sure about the F series transmission though.
Clay
tellerx
« Reply #3 on: August 29, 2009, 03:35:00 PM »
So what would be the difference between ordering one for the 5 speed in a 323 turbo as opposed to ordering one for the 5speed in a n/a 323
« Reply #4 on: August 29, 2009, 05:41:00 PM »
Hey Tellx!  None.  Gus
« Reply #5 on: August 29, 2009, 05:48:00 PM »
i have a complete linkage set for an xr2 both bars linkage shifter and all if your interested..
« Reply #6 on: August 30, 2009, 05:14:00 AM »
The n/a 323 shifter for the f series tranny is shorter by an inch...need the turbo unit
« Reply #7 on: August 30, 2009, 05:57:00 AM »
Tellerx do you have a turbo or nonturbo capri?
tellerx
« Reply #8 on: August 31, 2009, 03:34:00 PM »
The car with the shifter problem is a n/a
« Reply #9 on: September 01, 2009, 02:39:00 PM »
You might want to try a few of the quick fixes available to hold your shifter up. Sheetmetal screws, hose clamps...ect...  The stock shifter is supported by plastic clips that break.
tellerx
« Reply #10 on: December 11, 2009, 05:15:00 PM »
Ok Gents i want to thank u for the shifter info. Got her done last weekend, had to install the self tapping screws after i pulled the console and seats all the info i took from here gave me knowledge to accomplish the repar and came out pretty sturdy, thanx again
