Author Topic: Turbo  (Read 4132 times)
MJ
    • http://no
Turbo
« on: August 30, 2011, 09:34:00 PM »
Hi can any one please help the car runs really well but when l put my foot into it Turbo is boosting you can feel it and the boost gauge in the car is showing boost but it just seem to lack get up and go like you have hit the wall
Thank MJ
Turbo
« Reply #1 on: August 30, 2011, 09:44:00 PM »
I'm having a hard time understanding your post I'm sorry - the gauge is not showing boost? How many PSi / BAR?
MJ
    • http://no
Turbo
« Reply #2 on: September 05, 2011, 06:41:00 PM »
please help The motor and turbo has about 30,000 ks on them it has a 2 1/2 inch exhust high flow cat and K&N pannel air filter
I had the car dyno about six month ago the guy said I am getting 80 kw at the front wheels and it boost to 12 psi I borought the car about five years ago the hose that go down to the waste gate had a spitter on it one to the waste gate the other has a valve in the end which go out to the open air
Cheers MJ
Turbo
« Reply #3 on: September 05, 2011, 07:01:00 PM »
MJ,
The car is FWD. No power to the back wheels.
The car will hit boost cut at 10-11psi. Try removing the boost controller from the wastegate line.
12psi will make the engine cut if the boost cut switch is still there (which it should be, unless you are running a chipped ECU)
MJ
    • http://no
Turbo
« Reply #4 on: September 07, 2011, 06:13:00 PM »
Sorry it's fwd l have had too many rwd cars.
I took the spliter off the hose so there was only the one that went to the wastegate and it ran crap if the wastegate is not working fully is it a simple change or is there an aftermarket one that will fit and if so can it help performence.
Also what else can l do to my car to give it a kick along
Cheers MJ
Turbo
« Reply #5 on: September 09, 2011, 04:18:00 AM »
If it ran like crap at high boost, and then at stock boost, it is not a wastegate or boost issue. The car is running like crap due to something else.
You aren't being real descriptive of the actual problem though
You've had the car 5 years - has it always run this way? What has changed?
MJ
    • http://no
Turbo
« Reply #6 on: September 09, 2011, 12:14:00 PM »
Yes, l have had the car about 5 years and l dont run it very hard. However every now and then l give it a little bit.
As for the problem with boosting, l am not sure what is causing it at times. l've had full boost and it goes pretty hard but for most of time it boosts a little. l can hear the boost and see the guage show boost, but there is a lack of power or may another way of looking at it is the turbo is fully boosting but there is something stopping the the power. Could the dizzy have a intermiten fault which is a motor problem, not turbo problem? Or something like the knock sensor? l just want to fix it but do not know where to start (I am not a machanic.)
Thanks MJ
