Author Topic: Used stock short block for DFW (TX) area pick-up  (Read 3318 times)
CapriProject
« on: September 14, 2010, 02:35:00 PM »
When I bought my 1991 Capri it had a 'new' engine installed by the previous owner. In the trunk was the old stock block (steam cleaned then allowed to surface rust), the stock crankshaft, the 4 stock rods & pistons (labeled in order).
The past owner said he was going to re-build the stock engine when he found a "good deal" on Ebay for a 'new' factory replacement engine which he bought & installed.
I don't need those old parts but shiping them across country isn't something I want to hassle with (& won't). If there's someone close enough to the Dallas/FtWorth Texas area who is interested in these let's talk cheap.
CapriProject
« Reply #1 on: September 16, 2010, 03:21:00 AM »
Any suggestions other than the obvious (sell for scrap metal, take to the dump)?
« Reply #2 on: September 16, 2010, 12:37:00 PM »
Time... Stuff like this doesn't move quickly. If the crank & everything is good it might be marketable to the 323 GTX guys as well
