Pages: 1 [2]
Author Topic: My Capri is Broken  (Read 9846 times)
Blobfish
    • 1992 Ford Capri XR2
Re: My Capri is Broken
« Reply #15 on: February 13, 2023, 09:42:22 AM »
Finally started today! The fuel injectors were dirty and I think he said one of the valves was stuck because of the dirt as well. Now that my friend has cleaned the fuel system it starts and the idle is better. Still idles fast and surges when it warms up though. He thinks that a new IAC valve will fix the fast idle, so hopefully that's all it is and I'm on the home straight now.
« Reply #16 on: February 14, 2023, 09:13:01 AM »
We're hopeing for you.
Blobfish
« Reply #17 on: February 14, 2023, 09:48:44 AM »
Blobfish
« Reply #18 on: March 06, 2023, 06:55:57 AM »
I've installed a new IAC valve in the car and it seems to have largely restored the car to working order. Idles fast when it's cold and slows down to a smidge under 1000 rpm when it's warmed up.
« Reply #19 on: March 06, 2023, 08:32:21 AM »
Cool, that's what it does.
JJCapri
« Reply #20 on: May 01, 2023, 06:02:32 PM »
wonder if that's why mine runs at 1500 most of the time.. sometimes it will be 8-900 like it should, but mostly stays at 1500
« Reply #21 on: May 03, 2023, 09:24:45 AM »
When you park it for a few minutes, the IAC will warm up and it will idle properly, after you run it a few minutes it will go back up.
Blobfish
« Reply #22 on: May 09, 2023, 10:19:34 AM »
Have you tried testing the thermostat? I'm not going to guaranty it will help but it could at least be worth looking into if you want.
« Reply #23 on: May 10, 2023, 06:23:57 AM »
This is extremely promising information. Do you happen to know what your mechanic did to clean the injectors?
Blobfish
« Reply #24 on: May 11, 2023, 10:53:39 AM »
He used a GLR Injection Technologies machine - used to be called Mr Injector.
Blobfish
« Reply #25 on: January 14, 2024, 10:01:49 AM »
Well my Capri is dead again but at least I know why it won't start this time, the fuel injectors aren't receiving their electronic signal to fire. The ecu, distributor electronics and map sensor have all been tested, the ecu and map sensor are both ok and the dizzy electronics was inconclusive.
My prime suspect at the moment is the dizzy electronics because the seals have failed and oil is leaking into the dizzy. But I was wondering if there's anything else worth checking out that could cause the injectors not to receive a signal?
« Reply #26 on: January 14, 2024, 07:11:23 PM »
When you crank the engine, does the tachometer bounce? If not that is a classic sign of a failed ingitor module in the distributor, a fairly common issue
Blobfish
« Reply #27 on: January 14, 2024, 08:44:23 PM »
I thought it still bounced, but now that you ask I can't actually remember with certainty. And I haven't got those bits back that I got tested so I can't check it either  ::)
Pages: 1 [2]
