April 28, 2024, 04:00:40 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
General
Photographs
Will register as a 'motorcycle' project
« previous
next »
Pages: [
1
2
Print
Author
Topic: Will register as a 'motorcycle' project (Read 5498 times)
CapriProject
Full Member
on:
July 06, 2010, 08:15:00 AM »
Well, it's not going to be a good looking as your Capri 'cars' but this is the general look I think my 3-wheeled project will have. (Subject to constant changes)
http://farm5.static.flickr.com/4097/4768276231_0b736a6c9f.jpg
(hope the picture shows here)
Administrator
Old-Timer
Reply #1 on:
July 06, 2010, 09:35:00 AM »
I like that! The front end looks cool.
Need parts?? Go to
http://www.Roo-Sport.com
CapriProject
Full Member
Reply #2 on:
July 06, 2010, 02:40:00 PM »
Thanks,
The front 'open mouth' will be simular to the old AC Cobras. The hood will remain stock, I'll just follow the lines (minus the pop-up lights) & loose the bumper stuff. Twin 'side-pipes' share exhaust duties.
The back 'swing-arm' suspension will attach to the stock mounting points of the rear stablizer arms & taper in to support an 8" wide wheel. Coil-over-shocks will be the suspension. The rear wheel/tire will be right behind the stock fuel tank. Well that's the plan today suject to a dozen changes.
Old-Timer
Reply #3 on:
July 06, 2010, 03:44:00 PM »
CapriProject
Full Member
Reply #4 on:
July 10, 2010, 03:06:00 PM »
I cut & welded 2 stock Capri wheels to make the rear wheel for my 3-wheeler project. Each side of the wheel has a 'face' on which is a disc brake rotor. The rotors hold the 4 bearings (like stock)that will ride on the center axle. (like a regular motorcycle) The wheel is 9" wide & will have a 245/60/14 tire. It will have both stock brake calipers. FYI...Here's a link to the picture:
http://farm5.static.flickr.com/4138/4781761156_85af02cc66_b.jpg
Old-Timer
Reply #5 on:
July 10, 2010, 07:19:00 PM »
CapriProject
Full Member
Reply #6 on:
July 11, 2010, 04:31:00 PM »
Gostlrs...Thanks for posting the actual picture & not just a link (like I did ...I don't know how to attach a picture to my posts) I see where it says "HTML is not enabled" ..... anyway thanks again for posting the picture.
I'm building the rear suspension now so it will be a while before I've got a picture to post.
I figured for you guys this project of mine is like when you drive past a wreck on the road... you don't want to see anyone hurt, but you can't stop from looking anyway.
Administrator
Old-Timer
Reply #7 on:
July 11, 2010, 05:05:00 PM »
To attach a picture, first upload your pics to a photo site (Photobucket.com, etc.). copy and paste the address (URL) of the photo, after clicking on the blue "image" tab under the reply box (where you type the replies).
Need parts?? Go to
CapriProject
Full Member
Reply #8 on:
July 12, 2010, 04:03:00 AM »
Photo posting test:
Thanks...
CapriProject
Full Member
Reply #9 on:
July 15, 2010, 03:00:00 PM »
Welded the rear swingarm assembly. (In over 100+ degrees today). Here's a picture of it & the sideways adjustable stabilizer bar. I'll start on the detail points on it tomorrow. FYI
WickedClown
Jr. Member
Reply #10 on:
September 30, 2010, 01:28:00 AM »
well??? i need to see MORE!!!!!!!!!!!
CapriProject
Full Member
Reply #11 on:
September 30, 2010, 02:32:00 PM »
OK, bare with me here... progress has slowed while (needed) business has picked-up. The inner trunk sheetmetal is done, the rear swingarm suspension & wheel (brakes and all) are done, an 'inner-sheetmetal' panel is covering the stock wheel wells (not the out-side finished panel that will blend in with the body), I've only started on forming the mold for the fiberglass rear panel (ugly)...
Heavensheros
Old-Timer
Reply #12 on:
September 30, 2010, 02:37:00 PM »
that is going to look awesome !!! the 10 annual MACG would make the PERFECT time for first public appearance *WINK *WINK
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
CapriProject
Full Member
Reply #13 on:
September 30, 2010, 03:15:00 PM »
Believe me when I say "You're being too kind!"
The fiberglass & sheetmetal work is the slowest & the 'least-fun' part of this project. It's my planned tail-light setup that I'm looking forward the most to do but I can't until the rear panel is done. The tail-light will be clear plexy over a mirrored 'back-panel' with rows of red LEDs (the full width of the vehicle)& a clear 'defusing' panel (like some floresent fixtures have)to multiply the red 'points-of-lights'. Not being a 5' long normal RED lens will looked real clean & different. (IMHO) I've also finished making the polished 2" stainless steel side exhausts but that doesn't get installed 'till after final paint. Well that's the "up-date" for now.
WickedClown
Jr. Member
Reply #14 on:
September 30, 2010, 03:38:00 PM »
I like this project!! Are you expecting any stability issues?
Print
Pages: [
1
2
« previous
next »
General
Photographs
