April 29, 2024, 12:08:16 PM
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Classifieds
Capri Parts
WTB : Water Pump Pulley
« previous
next »
Pages: [
1
Print
Author
Topic: WTB : Water Pump Pulley (Read 3830 times)
Surfnut
Sr. Member
on:
August 04, 2014, 03:08:21 PM »
I need a water pump pulley for a '91 XR2. In fact, I wouldn't mind having two
I'm also semi-interested in a "V" belt crankshaft pulley (or two) - I'd like to have the "V" belt pulley that the serpentine belt pulley is bolted to.
Thanks,
Dave
Administrator
Old-Timer
91 BPT AWD Capri & 1991 XR2
Re: WTB : Water Pump Pulley
Reply #1 on:
August 04, 2014, 04:57:00 PM »
The one on the crank is called the harmonic balancer. It's more than just a pulley
From your pictures, I think you have the large-nose crank, but you'll need to confirm that. (there are two different crank styles & thusly different harmonic balancers)
Surfnut
Sr. Member
Reply #2 on:
August 04, 2014, 05:24:31 PM »
Hmmmm. I already torqued all that stuff down and I really don't feel like taking it all apart again - maybe I'll just stick with the water pump pulley(s).
As always, thanks Rocket!
Administrator
Old-Timer
Reply #3 on:
August 04, 2014, 06:51:40 PM »
The harmonic balancer is only held on by those 4 10mm bolts. The main crank bolt does not retain it.
Surfnut
Sr. Member
Reply #4 on:
August 08, 2014, 06:08:44 AM »
Does anyone have a water pump pulley I can buy? There has to be someone with a junk spare motor laying around?
Thanks,
Dave
Surfnut
Sr. Member
Reply #5 on:
August 23, 2014, 05:47:17 AM »
Okay, not having any luck at all finding a water pump pulley.
Can anyone please tell me what other vehicles used a pulley like ours? I assume early Miata?
Sr. Member
Reply #6 on:
August 23, 2014, 01:19:52 PM »
Yeah the last time I did a timing belt change I bent the pulley and used my only spare... where are you, no junk yards near you with a capri? You'll have a easier time finding a junked capri rather than an early miata or 323...
Sr. Member
Reply #7 on:
August 23, 2014, 01:27:38 PM »
F1CZ8509A is the part number, search that number, I find lots of places selling Tracer and escort parts with the same part number...
Surfnut
Sr. Member
Reply #8 on:
August 23, 2014, 03:50:08 PM »
Thank you very much for the part #. Do we know if a 1.6l Miata water pump pulley is the same as an XR 2 water pump pulley? (I found a guy who has 2 Miata pulleys)
EDIT : According to O'Reilly's, the Miata water pump is the same part number as the XR2 water pump - I assume they share the same water pump pulley?
Thanks again,
Dave
Last Edit: August 23, 2014, 03:54:35 PM by Surfnut
Administrator
Old-Timer
Reply #9 on:
August 25, 2014, 06:26:18 AM »
The early Miata water pump pulley is the same (pre-94, I think?)
The later models use a 4-rib pulley design which is actually better, but requires getting the harmonic balancer, water pump, and alternator pulleys as a set.
Surfnut
Sr. Member
Reply #10 on:
August 25, 2014, 02:38:36 PM »
I can always count on you Rocket - thanks!!
Print
Pages: [
1
« previous
next »
Classifieds
Capri Parts
