Pages: 1 2 3 [4]
Author Topic: something is not right HELP !  (Read 14002 times)
Heavensheros
« Reply #45 on: March 20, 2010, 12:56:00 PM »
yes but it idles rough again and will lean out when i give it little throttle and start to sputter and i will have no power at all ... the car is not running right. sometimes it will idle bad and then rpms will jump a little and idle fine. give little throttle and it leans out way bad and does not run good.
1992 Capri XR2
RocketMan VAF adaptor
Accel wires
Irundium IX
2.5\\" Thrush exauhst
Rocket Chip
Rims
H&R Lowering Springs
Tuner FX Racing seats
Gauges w/ A-pillar gauge pods
Accel superstock coil
FMIC
Heavensheros
« Reply #46 on: March 23, 2010, 06:02:00 AM »
some more info ....
idles fine ... give it gas and let go it will idle bad at 700 wait a few moments the rpms will jump to 1100 and calm at 900 and idle good again.
car warms up.
when driving sometimes it will run good and sometimes it will sputter and have no power boost will slowly creep up when about 5 it will get fuel and jump up and run good or if i give it full throttle it will get fuel and run good. i cant see it being a timing issue because it will do it sometimes.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Phillip
« Reply #47 on: March 23, 2010, 06:00:00 PM »
I was having a similar problem. At part throttle it would sputter and run like shit. Put it to the floor it would run like a mother. Found out it had to be a fuel problem by hooking a propane can to it through the capped bleed on the intake and turning it on when it sputtered. Check the relay and pump. Mine was the relay.
Intermittent Fuel pump problem.
« Reply #48 on: March 23, 2010, 06:05:00 PM »
B12 Chemtool.....
new plugs and wires as well....
Heavensheros
« Reply #49 on: March 24, 2010, 05:24:00 AM »
ok i will look into the fuel system a little more
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
« Reply #50 on: March 27, 2010, 01:14:00 PM »
where is the fuel pump relay ?
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #51 on: March 27, 2010, 02:56:00 PM »
Under the ECU
Heavensheros
« Reply #52 on: March 27, 2010, 03:16:00 PM »
thank you i put b12 chemtool into the gas today still isnt running good ... idle bad then wait a few idle jumps up and sits down and idles good going to check the relay maybe it has bad connection or something.
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
« Reply #53 on: March 27, 2010, 03:33:00 PM »
also since a friend will be doing it as well we are both also going to do a total seafoam on his car and i will be doing it to mine as well... couldnt hurt
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
Heavensheros
« Reply #54 on: March 31, 2010, 02:00:00 AM »
the problems are fixed .... bad TB gasket ...
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #55 on: March 31, 2010, 04:11:00 AM »
-__-
Heavensheros
« Reply #56 on: March 31, 2010, 05:30:00 AM »
gasket was super thin and wet on the bottom where coolant goes through ....
1992 Capri XR2
Accel wires
Irundium IX
Rocket Chip
Rims
FMIC
« Reply #57 on: March 31, 2010, 05:47:00 AM »
You haven't done a tb coolant bypass????
Pages: 1 2 3 [4]
