Author Topic: Narrow Band or Wideband O2 Sensor  (Read 2240 times)
« on: February 17, 2009, 04:14:00 PM »
so what type do we have? i need to get a A/F Gauge and i want yo grab the right one.
1992xr2
« Reply #1 on: February 17, 2009, 04:43:00 PM »
Factory is a narrow band, I highly reccomend dropping the 200-300 and upgrade to a wide band with logging, narrow band simulation and a display.
\\\'90 Civic Si
Boost in the near future.
« Reply #2 on: February 17, 2009, 04:48:00 PM »
Most OEM O2 sensors are narrowband. They're junk for trying to determine accurate A/F readings. They'll tell you rich or lean but not how much, and not fast enough. Thats all the stock ECU needs for closed loop operation in cruising conditions.
WBO2 is aftermarket...you'll need a kit. There are many to choose from. It'll tell you EXACTLY what AFR you're running. These sensors are pretty expensive, and usually require a driver module for the sensor heater and gauge. I have a PLX SM-AFR.
Heres a basic explanation: http://www.autometer.com/tech_faq_answer.aspx?sid=1&qid=48
« Reply #3 on: February 18, 2009, 03:24:00 PM »
thanks...
